Equivalent Mosfet
  • samanthban
    • Feb 2014
    • 253
    • Sri lanka
    Equivalent Mosfet
    please let me know any Equivalent for this fet - AO4406A .I have AO4406 is it compatible with this ??
    Thanks ..
    sigpic
  • cyberhack
    • Feb 2013
    • 466
    • Uk
    Re: Equivalent Mosfet
    Yep go ahead with that
    • subroto
      • Oct 2015
      • 230
      • Bangladesh
      Yes compatible
      • samanthban
        • Feb 2014
        • 253
        • Sri lanka
        Originally posted by subroto
        Yes compatible
        Thanks my friends
        sigpic
        • tofik
          MOSFET equivalent K8A60DA
          by tofik
          Hello guys,
          I have a shorted MOSFET K8A60DA with the following characteristics:
          Type Designator: TK8A60DA
          Marking Code: K8A60DA
          Type of Transistor: MOSFET
          Type of Control Channel: N -Channel
          Maximum Power Dissipation (Pd): 45 W
          Maximum Drain-Source Voltage |Vds|: 600 V
          Maximum Gate-Source Voltage |Vgs|: 30 V
          Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
          Maximum Drain Current |Id|: 7.5 A
          Maximum Junction Temperature (Tj): 150 °C
          Total Gate Charge (Qg): 20 nC
          Rise Time (tr): 25 nS
          Drain-Source
          07-19-2023, 05:18 AM
        • dreico33
          AON7403 Mosfet Equivalent
          by dreico33
          Hellow guys,
          I am trying to replace an AON7403 Mosfet but i dot not have in my stock the same. So i wonder if there is any equivalent to this Mosfet.
          Thank you very much.
          11-16-2024, 09:28 AM
        • Jane
          How do you test MOSFET in laptops ?
          by Jane
          I tried to use this method:
          Testing an N-channel MOSFET:
          Step 1: Discharge the Gate (turn off the MOSFET)
          Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
          Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
          Step 2: Charge the Gate (turn on the MOSFET)
          Now, place the red probe on the Gate (G) and the black probe on the
          09-27-2024, 03:31 AM
        • mohamed mm
          looking for equivalent mosfet for (IR3598MTRPBF)
          by mohamed mm
          I'm looking for an equivalent dule mosfet for (IR3598MTRPBF - Dual MOSFET Driver, High Side, and Low Side, 4.0V to 13.2V Drive voltage, 20 ns delay, QFN-16)
          it's for motherboard ram voltage.
          I hope someone can help me.
          Thank you.
          11-01-2023, 07:28 AM
        • jackx
          equivalent MOSFET 4C09B
          by jackx
          hello brother
          i need equivalent MOSFET 4C09B
          05-27-2024, 03:41 PM
