macbook Pro 2011 15" A1286 won't power on without battery
  • joelz
    • Aug 2013
    • 18
    • jakarta
    Hi, i just got this macbook, its wont power on without battery,
    because i have no battery inside.
    tried other battery, and it works, laptop charges, and start up normally, but if i remove battery, it will not work, i have 85W Power supply,
    what can i do?
    i cant do any resets..
    Its macbook Pro 2011 15" A1286
  • dellxps15
    • Feb 2014
    • 1588
    • italy
    Re: macbook Pro 2011 15" A1286 won't power on without battery
    post mainboard code: 820-xxxx. if it works on battery should be easy to fix.
    • nabilgo
      • May 2016
      • 300
      • L.A
      can you dump bios for me plz
      • cvorke
        • Oct 2012
        • 26
        • Solar system
        Same problem here...
        Motherboard 820-2915, won't power on without battery.
        If I connect battery and power it on, I can remove batt and it will remain on if connected to DC, but it won't start only on DC.
        It can powers on only on battery normaly.
        Looks like common problem because I have two mobos with same issue.
        Already changed U7000, but same problem persist.
        • inflex
          • Aug 2012
          • 544
          Do you get a green light on the magsafe?
          YouTube Repair Videos - https://www.youtube.com/user/19PLD73
          FlexBV BoardView software - Linux/OSX/Windows - http://pldaniels.com/flexbv
          • cvorke
            • Oct 2012
            • 26
            • Solar system
            I have green/orange light. Everything works fine, except power on without battery.
            I've just tested with ASD and it passed without any error.
            Very confused about this...
            • inflex
              • Aug 2012
              • 544
              Really can be a multitude of causes for this sort of fault; hopefully nothing involving the SMC.
              Do you have the boardview & schem ( I don't have that one in my small collection )?
              • cvorke
                • Oct 2012
                • 26
                • Solar system
                Problem was with DC adapter, works fine with new one...
                • Bowline
                  by Bowline
                  06-11-2025, 10:13 AM
                • gboone
                  820-00850 2019 MacBook Pro 13" Touch Bar (A1989) mysterious battery drain
                  by gboone
                  Hi, I was given this laptop by my uncle who said:
                  • It would occasionally shutdown if not plugged in
                  • battery had been replaced
                  • touchbar would "strobe"
                  I disconnected touch bar components and strobing and sudden shutdowns were fixed. Recent updates were installed to the OS.
                  After fully charging the battery, with bluetooth disabled, no LAN cable and only wifi enabled, the laptop stayed on (screen on) for about 6-8 hours. Allowing screen to turn off while not in use, and it went for over a day.
                  BUT
                  When powered off, it would at some point have a...
                  01-27-2025, 09:12 AM
                • mferna14
                  MacBook Air A2681 battery problem after Screen Replacement
                  by mferna14
                  Hi, my dear friends., Maybe this might be a stupid question or something I missed or do not know. I have 2 MacBook Air A2681 (Indentical color & EMC #), both LCD screens broken. Before ordering the LCD Screens I confirmed both worked with their respective batteries & AC Adapters, & they did 100%. The LCD Screens came in today & I replaced LCD for the 1st A2681. (Removed Battery Terminal cable for both Laptops before installation of LCDs). Perfect Screen & Booted up fine. But it did not work with battery. I checked the battery connector & it was seated in well/perfectly....
                  12-06-2024, 08:10 PM
                • mkdj
                  by mkdj
                  Mark and model: ASUS X571
                  Tests already made:
                  - I have removed...
                  07-14-2025, 09:16 AM
                • leonemax81
                  Macbook a1707 820-00281 Battery no Power
                  by leonemax81
                  Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
                  08-23-2024, 09:24 AM
