Different screen sizes
  • Hasith
    • Dec 2015
    • 35
    • Sri Lanka
    Is it possible to replace a LCD or LED screen in different size, without damaging the mobo or screen?
    Like replacing a 15.6 LED for a 10 inch one?
  • subroto
    • Oct 2015
    • 230
    • Bangladesh
    Re: Different screen sizes
    No brother. All screen come with a predefined resolution which is controlled by predefined BIOS value of a laptop. So if you will change the screen size most of the time nothing will appear on screen or some noise will appear.
    • Hasith
      • Dec 2015
      • 35
      • Sri Lanka
      Bump
        • 31258
        yes, if the interface and voltage and resolution is the same.
        it's not going to matter how large or small the glass is.
        if it's a laptop, you can even get adapters on ebay to connect an led backlit screen to an older type cable.
        • Hasith
          • Dec 2015
          • 35
          • Sri Lanka
          Oh, Thanks alot!
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • reformatt
            by reformatt
            07-31-2025, 08:37 PM
          • smic717394
            by smic717394
            07-25-2024, 10:16 AM
          • Chrissygizmo
            by Chrissygizmo
            02-10-2025, 12:33 AM
          • spice_disc
            Vizio TV M50-C1 reboot cycle and static on screen
            by spice_disc
            I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
            The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
            09-08-2024, 02:37 PM
