Acer Aspire V5-531, cannot power on most of the time
  • Acerman123
    • Apr 2016
    • 34
    • Finland
    So yesterday my brother's laptop apparently broke.
    It does not react to power button. I have disassembled it and measured that the power plug / cable is fine as well as charger of course.
    The laptop can be powered on by repeatedly connecting and disconnecting charger, occasionally it will power on automatically but without picture. Power button led and charge / power leds are flashing. The laptop cannot be powered off by pressing power button, it does not react to it. The laptop can draw power from charger and battery once it has been powered on.
    Something related to power is obviously broken from the motherboard? I have multimeter and sharp soldering iron so I could theoretically replace some parts from the mobo, maybe not the smallest ones. The thing is I don't know where to and how to start diagnosing possible failure.
  • Life Goes On
    • May 2014
    • 264
    • Curacao
    Re: Acer Aspire V5-531, cannot power on most of the time
    Maybe you can start with flash the bios to see what it does.
    The Night Drop Down, I Will Keep Try Until..., You Never know.
    Dushi Kòrsou, Nos Tei.
    • Acerman123
      • Apr 2016
      • 34
      • Finland
      The laptop does not power on always when I plug the power cord, it takes several connect / disconnect cycles and sometimes it does power on, but even when it does, there is no picture. Only blinking lights.
      • SanWilliams
        • Jun 2016
        • 15
        • peru
        Acer V5 - series
        espero que te sirve nos vemos
        • Acerman123
          • Apr 2016
          • 34
          • Finland
          I tried the reflow trick, put the whole board in oven. After that the laptop has worked without any issues. I know this is far from professional fix, but the issue was apparently bad solder joints somewhere.
          • mahmoodgl
            • Feb 2015
            • 10
            • arak
            goooooooodwork
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3577
              • slovakia
              very bad fix. come back when it start doing the same
              • PantherDave
                by PantherDave
                Hi all!
                05-29-2024, 02:01 PM
              • GLISIT
                by GLISIT
                01-16-2025, 02:29 PM
              • Bonaventure Vigil
                ACER ASPIRE A515-52G CAN ON BUT NO DISPLAY, NO POWER AT VCC_GT
                by Bonaventure Vigil
                Dear All,
                Please really2 need Help on this Acer A515-52G Motherboard Compal EH5AW LA-G521P Rev: 1A.
                At first this laptop can on, keyboard light on but no display. Open the motherboard, found out the PQZ3 Mosfet and PUZ3 ic near it burn. Refer picture below. Then I replaced both. All the power rail 3.3,5,1.2, 1.35, 0.8V have power back after i turn on the laptop except for the VCC_GT rail. Voltage at Power Supply showing 0.000A before turn on, after turn on it became 0.5 0.6A. Seem cannot boot and still no display. Then I replaced the PUG1 and mosfet, but the VCC_GT still no power....
                12-12-2024, 10:22 AM
                by sam_sam_sam
                03-31-2024, 02:12 PM
