New Members
This site is paid for using my salary. Please consider making a monthly donation of $8 to support the site. I will add supporters who donate monthly to the ad-free group
Please also introduce yourself here Introduce yourself here.
And finally, Read the Forum rules here.
please explain yourslef bether , CRACK , what crack ? , board models , what are the causes you are cheking on the device ?? be more specific , this kind of post are null here !
lol... u r right i have to explain what i min to say is that i have thisthoshiba l 300 laptop mother when i bend the mother bord or if i press it in the center area it works fine but if i bend it in the other back side it wont so that mins their is a crack(loss connection) between the component and motherbord printout
thanks
I guess it's Intel motherboard with Core 2 Duo family processor.
First find correct schematic and measure all main voltages. If they are fine as I assume, I would suggest to check both Intel bridges.
If you have equipment, try to reball SB first, it's much easier, if doesnt help, do very carefully NB.
helo evreyone
i have motherbord GA-EP41T-UD3L
the proccesor fan spin slowly and the (RST) LED in post card is flashing.
i check the MOSFET and VCORE and its ok..
i replaced many proccesors and nothing haapend.
i tried to charge the bios many times and its the same result.
the ram1.8v is ok.
the south and north bridges voltage is normal.
can anyone help me please?.
Issue:
Disc is showing as not supported when a disc is put in.
Here's what I've done, you can skip this if you just wanna know the question:
- replaced with a disc drive from a donor ps5 (honestly questionable if this is known to work)
- reflowed the disc drive connector
-reflowed the chip in question (shown on image)
- I will say this console was very dusty so it's conceivable that it got so hot that it made the chip joints cold and potentially other things on the board
i have a laptop [MB: 45326560 SPS: 921048-601] that refuses to boot, i think i found the problem but i'm unsure how to fix it tho. http://imgur.com/a/Zn0WTM1
i apriciate all the help i can get, thanks ��...
