Rework of laptop motherboards
  • KEVSPIT
    • Sep 2015
    • 62
    • Malta
    Need some information regarding pre heating/baking of laptop motherboard prior to removing and soldering large BGA chips like GPU and North bridge.
    I am aware that the BGA themselves need to be heated for 105 - 110°C for at least 5 hours but need info on how to get rid of moisture from the PCB and therefore avoid and pop corning on the PCB itself.
    1. Is it recommended to pre heat the motherboard to remove moisture from the PCB before removing a BGA?
    2. If so, what is the recommended temperature and time for preheating/baking?
    3. What equipment is required to perform such operation?
  • hopkok
    • Oct 2014
    • 178
    • Slovakia
    Re: Rework of laptop motherboards
    1, YES
    2, 100-110C for 24 hours, personally use 110C for 6-8 hours and never have any problem
    3, I use clasic kitchen owen, preheating 6-8 boards at once (saving electric energy)
    • passete
      Living=Sharing
      • Jun 2015
      • 487
      • France
      i never bake the mobo, just lift, clean mobo, clean bga, add new balls and solder it back.
      No clean insat flux for lift, tacky flux for new balls and reatach.
      • KEVSPIT
        • Sep 2015
        • 62
        • Malta
        Originally posted by hopkok
        1, YES
        Thanks for the advice. It looks like that I need to invest in a heat chamber.
        • KEVSPIT
          • Sep 2015
          • 62
          • Malta
          It depends on the humidity level of one's current location. I've already had bad experience with pop corning on the PCBs so in my case preheating and removing moisture is a must.
          • Sushi1808
            • Jun 2014
            • 35
            • Slovenia
            1. YES, absolutely, you don't know the environment and humidity to which these motherboards were exposed, prior to getting to your workshop.
            2. I personally use 110C for around 4-5 hours and never have any popcorning or similar issues. I also prebake all new chips at 110C for around 4-5 hours. I wouldn't recommend any higher temperatures because of the sensitivity of some of the components. They can withstand much higher temperatures but only for a few minutes.
            3. I also use classic kitchen oven and prebake around 4 boards at once, works great for this purpose. It has around 10C temperature deviation, if I set it to 100C it heats the motherboards to 110C (checked with IR and classic contact temperature meter).
            • rookieme
              • Oct 2014
              • 397
              • Greece
              I never bake boards that where in use during the previous month as they are ok with the temp during their working state.
              If any of them is out of use for several months I'll consider baking it for the sake of the bga chip if I'm reworking with reballing, if I'm replacing it I don't care.
              The is a rare state that the board could be out of use for some years, then you should bake it because it will go pop corn not only the chipset but the main pcb itself.
              I always bake new chips even the 2016+ for 24h at 125C - I 've red that it is the proper temp. After I store them sealed at airtight parts bags.
                Multifix 425-01 and 450-01 Rework Flux Datasheet
                REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
                - No Clean Formulations
                - Low residue
                - Range of activity to deal with different component solderability
                - Halide free
                - Suitable for dispensing
                - Compatible with solder coatings and/or No Clean flux cored solder wire product range
                Both products are supplied in syringes or cartridges for application by dispensing....
                10-07-2024, 06:02 AM
              • petemanuk
                BGA solder balls not connecting - help pls
                by petemanuk
                So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                11-16-2022, 05:21 AM
              • learnmore
                Recommended BGA Rework Stations
                by learnmore
                Hello Community,
                Based on your experiences and knowledge, which BGA Rework stations would you recommend for general use for an enthusiast at the low-mid-to-high price range? Based on what I've seen, £6000 may be considered high. I particularly like those with adjustable focus, built-in suction and ball alignment features, but I appreciate that they may be on the high end.
                Also any thoughts on the PUHUI T-862++ IR Rework Station, LY GXX models, WDS-XXX models?
                01-22-2024, 04:53 AM
              • petemanuk
                Help with IR6500 rework station
                by petemanuk
                I been playing with a recently acquired IR6500 rework station and watching lots of YouTube tutorials to see how to use it with not much success. I’ve only recently joined badcaps but going through the forums there is a lot of knowledge here, so though it best is if I ask my question here.
                1. Firstly is the IR6500 any good for BGA rework or should I be spending my money on a better one.
                2. The instruction manual is pretty useless on explaining how to set the PID loops (no information at all!!) both top and bottom heater for th Kp, Ki and Kd...
                10-14-2022, 12:31 AM
              • ugamazing
                Procedural question about BGA rework and removal of CPUs
                by ugamazing
                I have been working to develop a consistent and reliable method/workflow for removing, re-balling, and replacing CPUs on various MacBook Pro models (2015-2020).
                I have done OK so far, but there's one detail I need to sort out. I'm hoping someone much more experienced than myself may be able to shed some light:
                I am noticing the pulled CPUs (to be re-balled) come off fine, and they "look" fine as well, immediately when I pull them. However, within a few minutes, after cooling, the CPU chips develop a very, very slight curve/bend. It's SO SLIGHT, maybe a 1-2%...
                07-12-2022, 03:11 PM
