HP 8440P running slow
+ More Options
Posts
  • sonunigam
    • Aug 2013
    • 151
    • Pakistan
    Hello all,
    I'm experiencing a very strange problem in HP 8440P which is running slow when it boots up. . . I checked the Hard Drive and the HDD's health excellent.
    I've checked Ram and it is working fine on another Laptop. Can anyone tell me what should i do??????
    I'm in a big trouble....
  • TVRepairNoobie
    • Feb 2015
    • 158
    Re: HP 8440P running slow
    Look in task manager, processes tab and performance tab to see what your CPU percentage is at and check which process is taking up the highest CPU usage.
    • RJARRRPCGP
      • Jul 2004
      • 6304
      Originally posted by sonunigam
      Hello all,
      Sounds like bad-laptop-HDD-disease. Where the laptop HDD is slow for no good reason and you may get the speed restored by wiping the entire HDD and reinstalling everything! It's very likely a faulty HDD.
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      "Β‘Me encanta "Me Encanta o Enlistarlo con Hilary Farr!" -MΓ­ mismo
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
      • Comp_Pro
        820-01949 Running Slow Fast Fan ASD Software Download?
        by Comp_Pro
        Hello all,
        I'm trying to repair this A2251 macbook pro. Board is 820-01949. The original issue was liquid damage which all cleaned up well and the board was not heavily damaged. Unfortunately after liquid damage cleaning the computer is running extremely slow and the fan is running at full speed. Even the cursor is lagging. Because of this I can't use the built in hardware diagnostic to give me a clue as to what is happening. Does anyone know if Apple Service Diagnostic software is available for this model? Any other clues which could help me out? Seems to me there is an issue with...
        11-30-2023, 05:33 PM
      • aqibi_
        820-4924-A MBPr 2015 running slow, possible ME Region?
        by aqibi_
        MBPr 2015 13" Early 2015 820-4924-A
        Running slow, with SMC bypass works fine:
        It has a NVME SSD Crucial P2 (1TB), tried another NVME adapter too.
        - No water indicators tripped
        - Sensors using iStat /HW show sensible values, only airport showing 129 degree (which is common) since we don't have ASD for this year board.
        I have removed and dumped the EFI/BIOS:
        - does cleaning the ME Region make sense?
        Side notes
        1) I do not have the original nor compatible SSD to test with
        2) battery is showing service...
        05-06-2023, 07:44 AM
      • Harryrepair
        a1990 820-01041-A running very slow and high fanspin
        by Harryrepair
        I got this board for practice.
        It had a liquid damage around U5850.
        Cleaned it, ran a jumper and put back one missing resistor (R5850,47ohm) and cap C8286 (1UF).
        Fans are still spinning on maximum and machine is running very slow.
        I found PP1V8_S5 not present and CPUVR_PGOOD not present.
        Appreciate all help....
        03-12-2022, 11:09 AM
      • FALKLAN
        Running Line Voltage and Integrating LED Pods - Automotive
        by FALKLAN
        Howdy everyone! I hope all is well where ever you are!
        I'm attempting to integrate a couple of LED pods into an automotive reverse lamp circuit. The problem being, while the vehicle is running there is a 8.5v current present on the reverse lamp power wire. Needless to say is that all LED pods and lights dimly illuminate while the 8.5v is present, so the LEDs are always powered on while the vehicle is running. When the vehicle is shifted into reverse, the voltage changes to 12 volts.
        I am uncertain how to convert this line into a switched 12v output line for the LED pods....
        02-05-2025, 12:30 AM
