820-4924-A MBPr 2015 running slow, possible ME Region?
  • aqibi_
    • May 2023
    • 5
    • England
    MBPr 2015 13" Early 2015 820-4924-A
    Running slow, with SMC bypass works fine:
    It has a NVME SSD Crucial P2 (1TB), tried another NVME adapter too.
    - No water indicators tripped
    - Sensors using iStat /HW show sensible values, only airport showing 129 degree (which is common) since we don't have ASD for this year board.
    I have removed and dumped the EFI/BIOS:
    - does cleaning the ME Region make sense?
    Side notes
    1) I do not have the original nor compatible SSD to test with
    2) battery is showing service battery (it's down to 3700mah) - do not have a compatible one to try
    3) Tried with the Camera cable disconnected
    4) Wondering if booting from USB3 externally with internal SSD removed can help understand if it is a SSD issue.
    5) using genuine 65W MagSafe2
    6) Trackpad cable replaced since the last one was ghosting
    Thank you
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: 820-4924-A MBPr 2015 running slow, possible ME Region?
    Originally posted by aqibi_
    ... can someone please clean the MERegion for me (I have tried following a tutorial on youtube from perniov but struggled with installing some of the files)
    All bios requests must be posted in "BIOS Requests ONLY!" subforum:
    https://www.badcaps.net/forum/forumdisplay.php?f=40
    Become a Badcaps supporter
    Thanks to all supporters.​
    • aqibi_
      • May 2023
      • 5
      • England
      Originally posted by Vesko356
      Apologies I've updated my post to remove that sentence. Link here: https://www.badcaps.net/forum/showth...64#post1236564
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        Yes, i already saw that.
        Also, I saw you've committed another rule violation, because you are not allowed to make a new topic if there is an existing one.
        I've already moved your request.
        Be careful, read the rules!
        • reformatt
          • Feb 2020
          • 1549
          Try a serviceable battery first. Also run diagnostics with D at bootup to see if there are any errors reported.
          • smic717394
            Macbook Pro 8.2 2015 kernel task 100% and very very slow
            by smic717394
            I need a bit of help. I have a Macbook pro end 2011 8.2. I bought it of a customer cheap because it has a bulged battery. I replaced the battery and upgraded the ram 2x8GB total 16GB, and replaced the HDD with a SSD. What happens with this laptop is very strange and I don't know where to begin. The laptop doesn't panic, tha fans run normal even when the kernel is 100%. If I reset the SMS, will run normal for about 30 to 1 hour then the kernel_task goes to 95% and the laptop become unusable. If I reset the sms agail will run again normally for some time. I thought is the battery,...
            12-14-2024, 01:32 PM
          • Destroyer-Br
            [HELP] ME Region Cleaning Request – Motherboard GK5MP5X 1.0
            by Destroyer-Br
            I’m working on a laptop in which I replaced the PCH, but I’m unable to clean or rebuild the Intel ME region using FIT.
            When I load my dump into FIT, it only shows the Intel(R) ME Kernel section. The full ME region structure does not appear.
            If I manually replace the ME region inside the decomp folder and try to build the image, FIT does generate an outimage.bin, but the file is corrupted.
            After flashing it, the board does not power on — no signs of life.
            I’ve identified that the issue happens because my original dump does not contain a complete or valid ME...
            11-23-2025, 02:48 PM
          • tom3k
            Dell Precision 5540. Need clean ME Region
            by tom3k
            Laptop: Dell Precision 5540
            MB: LA-H331P Rev: 1.0(A00)
            Hi.
            I am looking for a clean ME Region 12.0.95.2489 Corporate H CNP/CMP-H B, A
            After extracting my BIOS in FIT the ME Region size is 7565 KB.
            However the ME Region files I fouud online are 11688 KB in size.
            Can someone help me find he correct clean ME Region?
            Thanks!
            Code:
            ║ Family │ CSE ME ║
            06-28-2025, 12:34 PM
          • Adenitz
            Clean ME region - a bit of theory
            by Adenitz
            Hello laptop repair experts,
            can someone plese, help me understand the significance of cleaning ME region in a BIOS dump file?
            I know that Manegement Engine (ME) data is part of BIOS/UEFI firmware. I know that it contains some HW specific data for the particular laptop.
            What I don't know, why do I need to clean ME region if I try BIOS dump file from another laptop (of course same type and model). I'm not sure if this is only because of the serial number (not sure if that is stored in ME region at all).
            Recently, I had a two cases where laptops (one is Lenovo Idepad...
            10-21-2023, 04:44 AM
          • platinumsteel
            Macbook Air 2015 Booting Very Slow and Stuck on apple Logo 99%
            by platinumsteel
            Hi guys i have my personal MacBook Pro 2015 820-00165 board that was working fine for more than a year and one day stopped working on my original Magsafe charger. It was turning on with my bench power supply. Opened it up and while diagnosing that somehow i ended up with a shorted smc.The line which was shorted was SMC_PM_G2_EN. I removed the SMC and short was gone. So all I had was another working donor board 820-3435 which i used to program it's SMC to 820-00165 using the SMCTOOL By MuertoGB.Took that SMC and use it on my 820-00165 board .And my board started working again. PPBUS_G3H 8.56V....
            03-18-2024, 05:16 PM
