Mac mini A1347 Late 2012 no power!
  • davis12
    • Nov 2012
    • 26
    • denmark
    No power indication at all, replaced Power supply and of course cable, but still no power going into the board.
    The power supply gives power testing with multimeter but when plugged into the board it shorts out and doesn't show any power, its like if the logicboard is shorting the power supply.
    I need schematic and boardview if im lucky, to test what shorten the board like that.
    If anybody have experience with this im willing to pay for guidance.
    • 31015
    Re: Mac mini A1347 Late 2012 no power!
    schematics are around on torrent / mule someplace.
    • davis12
      • Nov 2012
      • 26
      • denmark
      can't find it mate, searched all over with no luck..
      • rookieme
        • Oct 2014
        • 397
        • Greece
        As I can remember you get 12V from the power supply.
        As you said it gets shorted as you plug it at motherboard.
        So you have to strip out the motherboard from the case first, solder 2 wires [not too thin ones] at the 12V power rail and remark the polarity.
        After take a fresh AA batery and connect it for some seconds at cables with the proper polarity.
        Disconnect soon after and check with your hands to see where the M/B has heated up.
        Usually it is a shorted ceramic cap. Remove it - not really need to replace it.
        Good luck
        • davis12
          • Nov 2012
          • 26
          • denmark
          Good luck
          Thanks il give it a try!
          • PantherDave
            by PantherDave
            Hi all!
            05-29-2024, 02:01 PM
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
          • waakye
            Apple Mac Mini A1347 Late 2014 completely dead no power
            by waakye
            Hello guys,
            Thanks for all your supports. Really appreciate them.
            I have a late 2014 mac mini that is completely dead. No power led no chime and does not boot when the power button is pressed.
            I did all the PRAM reset and SMC reset an nothing just dead.
            I took the back cover off and noticed that the fan spin slightly then stop and the cycle of the fan spin and stop continues.
            Really hope someone can help me out again as this forum is the best out there.
            Thanks in advance.
            03-11-2021, 05:04 AM
            by sam_sam_sam
            03-31-2024, 02:12 PM
