Mac mini A1347 Late 2012 no power!
  • davis12
    • Nov 2012
    • 26
    • denmark
    No power indication at all, replaced Power supply and of course cable, but still no power going into the board.
    The power supply gives power testing with multimeter but when plugged into the board it shorts out and doesn't show any power, its like if the logicboard is shorting the power supply.
    I need schematic and boardview if im lucky, to test what shorten the board like that.
    If anybody have experience with this im willing to pay for guidance.
    • 31613
    Re: Mac mini A1347 Late 2012 no power!
    schematics are around on torrent / mule someplace.
    • davis12
      • Nov 2012
      • 26
      • denmark
      can't find it mate, searched all over with no luck..
      • rookieme
        • Oct 2014
        • 409
        • Greece
        As I can remember you get 12V from the power supply.
        As you said it gets shorted as you plug it at motherboard.
        So you have to strip out the motherboard from the case first, solder 2 wires [not too thin ones] at the 12V power rail and remark the polarity.
        After take a fresh AA batery and connect it for some seconds at cables with the proper polarity.
        Disconnect soon after and check with your hands to see where the M/B has heated up.
        Usually it is a shorted ceramic cap. Remove it - not really need to replace it.
        Good luck
        • davis12
          • Nov 2012
          • 26
          • denmark
          Good luck
          Thanks il give it a try!
          • JimmyKmodding
            mac mini 2011 a1347 631-1740 no power
            by JimmyKmodding
            hello, I encountered an issue with the mac mini a1347 mid 2011 with the motherboard model being 631-1740. I tried to upgrade its dual hdd setup with ssds and upgrade the ram to 16gb. I also took apart the whole thing to replace the thermal paste. after putting everything together, it refuses to power on. I have no idea what the issue is and no idea where to start. I did check the voltage at the motherboard connector and I do get 12 volts. what else should I check?
            12-15-2025, 09:56 PM
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • PantherDave
            by PantherDave
            Hi all!
            05-29-2024, 02:01 PM
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
          • mrrubik
            HP Elitedesk 800 G6 mini - No power/no beeps
            by mrrubik
            I have a very strange issue with a HP Elitedesk 800 G6 mini (35W) unit - I acquired it as a barebones unit (no CPU/RAM/SSD), when plugging in power without any of this, I receive the correct 3 long, 5 short beeps (CPU initialization error).
            I acquired the correct CPU for this, an i5-10500T and 8GB of RAM, after installing it into the motherboard:
            1. Plugging in power adapter does not trigger auto-initialize (quick fan spin/power on check), the AMBER LED below motherboard does blink to indicate power connected
            2. Pressing power button does not turn unit on, the white
            08-23-2025, 09:22 AM
