Pin out of Reneas r2j24020F
  • bicalov
    • Nov 2014
    • 294
    • Netherlands
    Hi Folks,
    Can anybody help me to get the pin out of Reneas r2j24020F ?
    This is a smart battery chip in the battery pack from the Dell latitude E4310.
    I roamed the internet, but I can't find the pin out.
    Most links lead to datasheet sides, but no pin out in the doc from this chip.
    • 31003
    Re: Pin out of Reneas r2j24020F
    look at page14,
    they may be alternate part numbers based on the package.
    • bicalov
      • Nov 2014
      • 294
      • Netherlands
      thx stj,
      my chip has a QFN48 housing, which is not listed there. I have seen a lot of the available doc, but nowhere the pin configuration.
      So you might be right, that the partnumber is differfent. I found the M37512 (also Renesas) as being compatible, but I do not know if it is pin-compatible.
      • paulstef
        • Dec 2013
        • 724
        Can you post a picture of the chip?
        The one that stj found (and me too) seem to be related to p-channel mosfets while yours seems to be a uC.
        • bicalov
          • Nov 2014
          • 294
          • Netherlands
          The picture from the battery is bad, so I put a clear chip picture also.
          • paulstef
            • Dec 2013
            • 724
            No luck finding any info. The 20F seems to have 56k of flash memory and the 22F 96k. Preprogrammed... Does that mean it comes with a fixed software already when you buy it? Who knows.
            • bicalov
              • Nov 2014
              • 294
              • Netherlands
              thx paulstef, when you look at the M37512 in the software tools for them, the M37512 and the r2j240 are mentioned in the same line.
              Now I need this program and rather for free.
              • fzabkar
                • Mar 2009
                • 772
                The screenshot appears to be related to a TI EV2300 evaluation module:
                http://www.ti.com/tool/ev2300
                It is very similar to the screenshot in this thread, albeit from a different TI gas gauge IC:
                https://www.badcaps.net/forum/showth...t=50412&page=2
                Try the tool for the BQ2060A. It's a different chip, but perhaps these chips follow some standard in regard to the registers.
                • bicalov
                  • Nov 2014
                  • 294
                  • Netherlands
                  Good info, thank you fzabkar.
                  Regretfully the software link does not work anymore, but in my picture you can see the V2300 from TI next to Renesas M37512 and R2j240 you can choose one of them. The software from Regedit is very expensive and I didn't find it elsewhere yet.
                  • fzabkar
                    • Mar 2009
                    • 772
                    Please check that other thread again. I've uploaded the software for you.
                    • fzabkar
                      • Mar 2009
                      • 772
                      Here are some road maps and block diagrams that might help to determine what is inside the R2J24020F. It appears that it consists of a 16-bit MCU plus an AFE (analogue front end?).
                      The M37512 is just an 8-bit MCU that is mated with an external AFE, so the R2J24020F is a completely different beast. I expect that they are register compatible, though.
                      • bicalov
                        • Nov 2014
                        • 294
                        • Netherlands
                        Thx a lot fzabkar,
                        I installed the software and try to figger it out now
                        In the mean time I did a reset on the r2j240 pin 15, like the pin out from M37512, by putting it to gnd. Something changed, the battery led turns blue every now and than and after a while he flashes amber again. On top of that, windows can't find the battery anymore. So I assume the chip is cleared. Now see what I can do with the program and the flow charts.
                        • fzabkar
                          • Mar 2009
                          • 772
                          You could compare the serial clock and data pins of your module's connector against the M37512 pinout. That should tell you how close the pinouts are. You may find that they are totally different, in which case one would have to wonder whether you did in fact short the reset pin. You could also identify the ground and supply pins on your R2J24020F and compare them against the M37512.
                          • bicalov
                            • Nov 2014
                            • 294
                            • Netherlands
                            It is crazy that there is nowhere a pin configuration to be found from the r2j240.
                            I will try to do it your way.
                            If you look at the pictures, some crazy things happened
                            • fzabkar
                              • Mar 2009
                              • 772
                              All data are 0xFFFF.
                              It could be that the R2J24020F is not compatible with the software for the BQ2060A.
                              • bicalov
                                • Nov 2014
                                • 294
                                • Netherlands
                                That is correct, but also possible that the reset worked?
                                • fzabkar
                                  • Mar 2009
                                  • 772
                                  There must be commands that are standardised so that the OS can communicate with any battery in general terms over the SMBus, but there must also be manufacturer specific commands that allow the manufacturer to calibrate and program his particular device. I have no idea what happened when you shorted that "reset" pin.
                                  It's easy to be wise in hindsight, but I would have started by identifying the known pins, ie Vcc, Ground, SCL, SDA. There would also be an 0.1 ohm resistor for current sensing, and of course the BAT+ pin.
                                  • bicalov
                                    • Nov 2014
                                    • 294
                                    • Netherlands
                                    You are right, it would have been wiser, but I can't find any pin configuration so I had to gamble about the compatibility with M37512, This happened before your first suggestion, regretfully. Now the onliest possibility I have is the program from Regeditvn.com M37512-R2J240-EV2300 which seems to run directly on the laptop without programmer.
                                    But that one is way to expensive for a single job and I can't find any other.
                                    the pdf file shows exactly the what and how of the chip,but not the pin configuration. Here I noticed the reset availability.
                                    • acedogblast
                                      by acedogblast
                                      11-02-2024, 05:13 PM
                                    • brispuss
                                      Ryobi 36V (aka 40V) 6Ah Faulty Battery Pack
                                      by brispuss
                                      Purchased a Ryobi 36V 6Ah battery pack maybe just over a year ago.
                                      Battery pack had been used on about 3 or 4 occasions for powering a cordless lawnmower. I was wanting to use this battery pack again recently, but on checking the battery charge state via the battery pack test button, there was no LED indication at all of charge state which suggested the pack was fully discharged.
                                      I found this to be odd as I usually fully recharge battery packs shortly after use. So either the pack developed some sort of fault which completely discharged the pack cells (after recharging),...
                                      12-28-2022, 02:58 AM
                                    • Loki_Fido
                                      Help identify this chip please folks....
                                      by Loki_Fido
                                      Hi folks,
                                      Hope everyone's doing well.
                                      I have a HP ProBook 450 G9 came in for repair. This driver is shorted and im looking to buy a replacement. But i cant identify this chip.
                                      I checked our BadCaps sticky on following site
                                      https://www.badcaps.net/forum/troubl...and-datasheets
                                      But the name of the chip is wrong. I checked based on GND on chip.
                                      If you check on above link, you'll think this chip is SY8388ARHC, but if you search...
                                      07-03-2025, 02:31 AM
                                      by SMDFlea
                                      Bad...
                                      09-02-2021, 04:40 PM
                                    • BMCappelletti
                                      Asus Chromebox CN62 - wrong chip put on BIOS reader
                                      by BMCappelletti
                                      Long story short:
                                      - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                                      - gave the computer to his son a couple years later
                                      - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                                      - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                                      (seems like the story was not that short)
                                      He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                                      01-08-2025, 07:27 PM
