Logic board repair help needed please please
+ More Options
Posts
  • lcdcaps1
    • Oct 2011
    • 322
    Re: Logic board repair help needed please please
    hi
    i have checked
    • lcdcaps1
      • Oct 2011
      • 322
      ooops, sorry pressed enter too quickly
      no shorts on l7900
      no power on pin 1 on u7900
      but i have checked incoming voltages on j6990
      pin 8 i get 19v but pin 1 i get 13v
      please help
      thanks
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8670
        Not enough information...what board, pictures of board, etc., etc.?
        Found a schematic?
        • dellxps15
          • Feb 2014
          • 1585
          • italy
          voltage on q7950
          • lcdcaps1
            • Oct 2011
            • 322
            hi
            i have pasted a link to schematic in my previous message
            My concern is that I am not getting 3v on pin 1 on the DC-In Connector (J6990) this is on the macbook pro connector but I have looked online at the DC IN BOARD block diagram, (google images) and I see that u7600 deals with stepping down the voltage.
            http://notebookschematic.com/wp-cont.../A1212-LIO.png
            If I replace this will i get the right voltage measurements on J6990.
            Please advise
            • wibble
              • Jan 2011
              • 31
              #26
              >>I checked the RAM, one by one in each slot
              Try without RAM, if you can get it to turn on and it beeps, this will tell you that the problem may not be voltages, but one of the ICs.
              The SMC is a BGA. It has a triangle on it which points to pad A1, there is a test point just outside the opposite corner which should indicate 3V (not 3.42V) supply voltage to SMC. I think it's pads N14 and N15, it is marked on the schematic.
              Generally, if you have a green light on the charger it is a relatively good sign that the basic power circuits may be working correctly.
              At this point it is difficult to diagnose without clear measurements of the S5 voltages at the standard test points, such as on the coils.
              • lcdcaps1
                • Oct 2011
                • 322
                #27
                Hi
                Yes tried with them.in.both slots and.without but same.symptoms
                symptoms
                If the charger is plugged it.doesn't.turn on when.pressing the power button or jumping pads. Pwr on but if I try just the battery it does give reaction.to.power button being pressed or jumping the pwr on.pads. but doesn't boot or stay on. Fan moves and.haed.spins.up.then shut down
                If I remove charger and.plug.it in.it.does the same.thing
                I mentioned this earlier
                I started doing measurements an found that
                on j6990 pin 8 i get 19v but pin 1 i get 13v
                According to schematic diagram I should be getting 3v on.pin 1
                I tested voltage directly.on.the pins of the connector on the motherboard.
                My thinking is That I need to correct this before moving forward..
                Logical thinking suggests this right?
                I looked on the dc in board diagram and there is a chip
                u7600. Will this be faulty. Should I replace.
                If it does not stay on then how can I provide certain voltages
                Also which measurements do you need for q7950
                What's the best way to test and to know it is working.
                Please note the system doesn't stay on. Only have green light on charger and when battery plugged in changes to red. I think the colour is red
                Please help
                • dellxps15
                  • Feb 2014
                  • 1585
                  • italy
                  #28
                  u7600 is for 1.5 volt.
                  voltage on q7900 ? post picture of u7900 zone with high quality.
                  • lcdcaps1
                    • Oct 2011
                    • 322
                    #29
                    hi
                    i was talking about u7600 on the dc in board ( LIO board) this should be
                    5V S3/S0 SUPPLY
                    3.3V S3/S0 Supply
                    how can i check voltage on q7900 when it is not starting up
                    My concern is that why am I not getting a 3v but instead geting 13v on pin 1
                    this is on j6990 corrector that connected to the DC-IN BOARD (left IO board) to power the logic board
                    can some one please advise if I should replave u7600 on the dc-in board
                    please
                    thanks so much people
                    • wibble
                      • Jan 2011
                      • 31
                      #30
                      Just for clarity.
                      S5 voltatges should be always present when charger is plugged in.
                      S3 and S0 voltages only present after power-on pressed (or power-on pads).
                      Also before diagnosis you ideally need to establish that your charger is good. It should be 85W genuine Apple power supply. You can try a different charger or try your charger in a different laptop to be sure.
                      • lcdcaps1
                        • Oct 2011
                        • 322
                        #31
                        hi
                        the charger works have tested it
                        i will check the measurements and report back
                        but could some one clarify about the 13v problem, is this normal
                        thanks so much
                        • lcdcaps1
                          • Oct 2011
                          • 322
                          #32
                          Hi
                          I have been doing some measurements and have found out that u7800 has no power coming in on any pins and nothing coming out
                          does this mean that i need to replace this or need to replace the diodes before. (can someone confirm which diodes these are, please)
                          Thanks so much
                          • wibble
                            • Jan 2011
                            • 31
                            #33
                            According to the schematic, U7800 is LT3470 (the regulator for G3H power rail) are you sure? Or did you mean U7900
                            • howardc64
                              by howardc64
                              Problem
                              08-04-2024, 10:36 PM
                            • m1ch43lzm
                              by m1ch43lzm
                              05-12-2025, 08:37 PM
                            • Yanleb
                              LG 60PK550 Logic Control Board EBR63450301
                              by Yanleb
                              Hi all, I just want to share the repair of my 60PK550-UA TV set.
                              The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                              But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                              All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                              C57: 3.30V
                              C61:...
                              07-20-2023, 12:38 AM
                            • boosti45
                              MacBook logic board 820–01949 repair help needed please
                              by boosti45
                              I have a 2020 MacBook Pro touch bar 13 inch with the board 820–01949 that I'm currently working on that is my personal computer and long story short quit working got 5 V and no amps found out the computer was in DFU mode and I finally got it to go through and get on, and it would make it about halfway through, and then it would freeze while reviving so I would end up turning it off and starting over and on the third or fourth attempt I decided just to let it sit there and be frozen and see if it eventually finished and I came back like 15 minutes later and the computer was off and so I ended...
                              09-12-2024, 12:32 AM
                            • korben_dallas
                              Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
                              by korben_dallas
                              Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
                              I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
                              I'm new to soldering but the only feasible way to fix this issue is to do something myself.
                              MY QUESTION:
                              I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
                              02-14-2024, 12:23 AM
