Get rid of terrible thermal pads with this innovative Greek product
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    http://www.computer-systems.gr/en/products/k5-pro
    I use it without problems till now.
    i would like to read a review online for K5 Pro, comparing it with several thermal pads.
  • rs232killer
    • Feb 2015
    • 89
    • Portugal
    Re: Get rid of terrible thermal pads with this innovative Greek product
    i am using that for the last 3 months, so far so good.
    Just have concerns regarding long term behavior and the poor "package" that reflect most likely low grade industrial facilities
    we dont apply for more than 0,5mm gap, even if doesnt take thermal pad we apply in some reball cases becuase the chip gets unbalanced (dont remenber the right word atm)
      • 31281
      so where do you buy it?
      • rs232killer
        • Feb 2015
        • 89
        • Portugal
        ooo forgot to mention
        in a 0,5 mm gap we have similar performance of an 5W/mk laird pad so again stays a bit far from announced, so we will keep on testing.
        • goodpsusearch
          • Oct 2009
          • 2850
          • Greece
          http://www.ebay.com/sch/m.html?_nkw=...ems.gr&_sop=15
          I ordered a pack of 3
          Available also: http://www.amazon.com/viscous-therma.../dp/B00K04D3UK
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            I've noticed it a while back but seemed overpriced. Copper pads and MX-4 ftw.
            A working TV? How boring!
            • rs232killer
              • Feb 2015
              • 89
              • Portugal
              all mighty ebay (first sample was sent by a friend from greece)
              • rs232killer
                • Feb 2015
                • 89
                • Portugal
                send a sample .... to propper crosscheck:
                Thermal conductivity: 0.587 +/- 0.001 W/m/K
                Thermal diffusivity: 0.333 +/- 0.003 mm2/s
                Volumetric specific heat: 1.76 +/- 0.02 MJ/m3K
                was analysed on this
                http://www.hotdiskinstruments.com/pr.../tps-3500.html
                the writen report to me was "do not use this above 0,3mm".
                I Am waiting for the results on laird 0,3mm to compare.
                • goodpsusearch
                  • Oct 2009
                  • 2850
                  • Greece
                  I can't trust something like that so easily. If it was so simple to measure thermal conductivity don't you think there would be comparison charts all over the internet with stated and real value of every thermal paste?
                  • rs232killer
                    • Feb 2015
                    • 89
                    • Portugal
                    Hi
                    what we can't trust for sure is the 4w that they announce, by other hand i am waiting for results on the laird thermal pad which will be comparative directly to the test done on this paste.
                    The reason i pursued this test was because i wanted to know if i apply or not for resale of this product in iberia... we are talking about a lab in UK that sells lab equipments for industry, lots of €€€€€ each equipment probably that's the reason why you dont see charts over internet and everyone announce whatever it wants.
                    ps. there are charts about thermal behaviour of materials this compounds are simply a mix of it.
                    • goodpsusearch
                      • Oct 2009
                      • 2850
                      • Greece
                      I agree with you. Those numbers are 99% marketing and only 1% truth. What I am trying to say is that when you buy this product you don't care about ground breaking performance, you just want to solve 2 problems:
                      Cheap thermal pads applied from factory that dry and break resulting in IC overheating and failure.
                      Low thermal conductivity right out of the box, that is going to be an aging factor for bga ic.
                      So, if that viscous thermal paste doesn't dry and deteriorate with time (no-one can say for sure) and has a performance even hardly better than factory applied pads then it's perfect for me.
                      ps: I've ordered and tried Phobya thermal pads with 7W /mk and used them in laptop gpu. I was not satisfied with the result, still it wasn't even remotely close to designs that use thermal paste instead. Not to mention it was insanely expensive.
                        • 31281
                        if you want pads, contact Kerafol or Bergquist, they are the experts.
                        http://www.kerafol.com/en/thermal-management.html
                        http://www.bergquistcompany.com/ther...ials/index.htm
                        this page does not inspire confidence that they even make anything!
                        http://www.phobya.com/en/company.php
                        • mockingbird
                          • Dec 2008
                          • 5488
                          I've seen (and bought) Chinese thermal paste with an incredibly high W/mK rating. But if it were really that good, it would cost as much as Shin Etsu's highest prices stuff.
                          Same with this Greek product. It's been around for a while, but I never took their W/mK rating seriously. It's a great idea, but there's no way they're getting that kind of performance for what they're selling it for.
                          The problem with Laird pads is that you don't always know the correct thickness that you need. And Th3_uN1Qu3's copper shim method isn't always possible (like rs232killer points out). Sometimes the chip is uneven and a copper shim would leave a small gap because of this. Yes, you can compensate with the thermal paste you're applying on both sides, but only to a certain extent.
                            • 31281
                            just because you make a good product does not mean you have to rob the customer!
                            if a compound is based on carbon or graphite or berylium - hell even if it's based on silver, it should not cost more than gold by weight!
                            • mariushm
                              • May 2011
                              • 3799
                              I disagree.
                              It could be that the product is extremely hard to make in volume (or it's very hard to scale up production), or maybe there's a huge amount of energy required to produce it, or the process takes a lot of time. It could also be that it took a huge amount of work to make it (in case of niche software, maybe it took thousands of man hours to make it and the wages of those programmers need to be recuperated from something sold in small quantity) All these can make the product more expensive.
                              Here's for example a food example, it takes about 12 days to cook several portions of this, so I think you'd be justified in charging much more than the raw ingredient price : https://www.reddit.com/r/FoodPorn/co...lowed_by_a_48/
                              But in this particular case, I agree with the people that don't trust the advertised specs. There's also the issue of stability of the composition in time.
                              It looks like a decent product but only time will tell if it's really good or not... and with such an unknown company you never know if they'll keep the quality and the manufacturing "standards".
                              • goodpsusearch
                                • Oct 2009
                                • 2850
                                • Greece
                                The company is quite reputable here and the product is a result of a long research. That doesn't mean anything about its long time endurance of course. But there are no alternatives. Good thermal pads cost a fortune, and are not good enough in the first place. Not convinced about their durability too,
                                I haven't used copper shims yet. I ordered some recently and I am looking forward to conduct some tests to find the actual difference between thermal pads, K5 pro and copper shims.
                                stj:
                                Phobya is known between the overclocker community and their pads seem to be quite reputable. I don't care if they buy the pads from someone else as long as I know the product is among the best pads commercially available out there. Of course there are better but they are even more overpriced. Thanks but no thanks. I would rather use K5 pro unless it is proven that it's performing even worse than the thermal pads that come with laptops.
                                mockingbird:
                                You are right about the thickness issue. It is often critical to use the right thickness needed in a specific application. Even 0.3mm difference could result in 15 C temps increase!
                                • goodpsusearch
                                  • Oct 2009
                                  • 2850
                                  • Greece
                                  Want to know what Asus uses for its laptops in place of thermal pads?
                                  http://www.bergquistcompany.com/ther...iller-1000.htm
                                  This research claims that K5 pro thermal conductivity is indeed 5w /mk
                                  • rs232killer
                                    • Feb 2015
                                    • 89
                                    • Portugal
                                    not discuting methodes of doing lab experimentes but thermal condutivity is a bit more complex than do it by samples and comparation over home made experiments whith some mid grade equations. (really they used a IR meter on that "abstract" to mesure temperature)
                                    see the portfolio of the guys that tested k5 for me
                                    Its not rocket sience but i dont know how the hell they reached the 5w value, never the less the k5 paste is beahving relativly good on filling small gaps, there are many commercial thermal pastes that have a rather low thermal conductivity.
                                    • goodpsusearch
                                      • Oct 2009
                                      • 2850
                                      • Greece
                                      So, laird is a thermal pad brand?
                                      • rs232killer
                                        • Feb 2015
                                        • 89
                                        • Portugal
                                        hi
                                        yes, they manufacture for several areas including aeronatical and automotive
                                        ex.
                                        http://www.lairdtech.com/products/tflex-700
                                        products have certification btw
                                        • sancho76
                                          thickness of thermal pads for Alienware M15 R1
                                          by sancho76
                                          Hi, somebody knows the thickness of thermal pads for M15 R1? Or if someone have this Alienware model, can take measure for original thermal pads.
                                          02-01-2025, 03:19 AM
                                        • Veyron7887
                                          Laptop overheating after replacement thermal paste
                                          by Veyron7887
                                          Hi. I have Asus X55C laptop from year 2013. It has i3-2328M CPU. I replaced stock thermal paste with high quality thermal paste. Before thermal paste replacement, I measured CPU temperature Around 65-70 degrees Celcius with stock thermal paste. If after the replace thermal paste, I measured CPU temperature around 80-84 degrees Celcius and fan don't stop when system is idle. I replaced the thermal paste several times but still did not change. Where is the problem?
                                          11-24-2024, 05:08 AM
                                        • Gcnewbie
                                          Dell Latitude 5570 Ambient thermal sensor reading -127 Degrees C
                                          by Gcnewbie
                                          Forgive me this is my first request for help on this forum, so if i've screwed up or not followed the rules i should have i apologise profusely.
                                          I have a Dell Latitude 5570 that was randomly shutting down, on further investigation i found that the machine had been shutting down due to thermal events as noted by windows event viewer.
                                          My investigations lead me to the dell diagnostics screen, where i found that there were two sensors out of range which had been causing the shutdowns, one of which was the GPU thermal sensor and the other the ambient sensor.
                                          I opened the...
                                          03-29-2024, 06:55 AM
                                        • madan1
                                          Oily thermal pads
                                          by madan1
                                          Hi everyone.
                                          a quick question - is it normal thermal pads to be oily? I mean - used thermal pads ( already installed ).
                                          I do not have much experience with those, only bought new ones with adhesive and they were dry.
                                          So, is it normal the thermal pads to appear moist/oily ( probably to help the thermal conductivity ) or this is a clue for a water damage or something else?
                                          12-22-2018, 01:01 PM
                                        • caspian
                                          Can thermal paste cause corrosion?
                                          by caspian
                                          Dear members,
                                          I have got an ordinary gray thermal paste that has no name/model on the box.
                                          I put some of this thermal paste on a 128-pin QFP IC. A bit of this thermal paste was put on pins of the IC.
                                          I tried to clean the pins by thinner but the thermal paste cannot be cleaned from the pins properly. because the pins are tiny and the thermal paste is stuck between them.
                                          Is it possible that the thermal paste damages pins of the IC in long term by creating corrosion or something?
                                          Is it safe to leave the thermal paste on the pins?
                                          I guess the thermal paste...
                                          06-19-2020, 10:47 AM
