Does anybody recognize this ic?
  • lezsimply
    The Wanderer
    • 647
    • Philippines
    Can someone please help me identify this ic, please check image. It came from an unknown laptop brand. Owner only sent me the board and charger. After pressing power button led lights up and goes off after 2 seconds. This ic is heating up. hope someone knows. Thanks
  • lezsimply
    The Wanderer
    • 647
    • Philippines
    Re: Does anybody recognize this ic?
    oh by the way. prints on this chip is 412A 0945 Z793. thanks again
    • KEVSPIT
      • Sep 2015
      • 62
      • Malta
      That is an SC412A from Semtech
      • lezsimply
        The Wanderer
        • 647
        • Philippines
        thanks very much kevspit. Now I have 2 motherboards here which have same problem, can't find parts locally so gonna stock this one first. But I'll try to salvage from other laptop if possible
        • Stachujones
          Dell XPS 13 9370 unknown USB devices in device manager
          by Stachujones
          Hello, i bought a faulty Dell xps 13 9370 after installing windows in device manager i Can see 2 unknown devices, one is thingerprint reader because it dissapears after i unplug it and second one is i believe bluetooth because it also doesnt work and in bios there is no bt also.
          Device manager says "unknown device, failed to request device descriptor"
          Can somebody point me in right direction what to check?
          I updated bios to the newest version and thunderbolt controller firmware still no luck
          04-05-2025, 07:35 AM
        • apostsamking
          dell latitue e5450 AC Adaptor unknown
          by apostsamking
          Hello everyone hope all is well. Pls I bought this second hand dell latitue e5450, I realize that the battery cannot be charged because it says ac adopter unknown at bios. I tried several chargers but still I get the same messageAC Adaptor unknown. So I open the laptop up checked the motherboard and i realised that the diod PD5 is fried so I changed, but I still get the same message, changed even the charging ic still the same message AC Adaptor unknown. Can any one help me?
          02-19-2023, 03:45 AM
        • TheUser
          Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
          by TheUser
          Hello to everyone ,
          This is my first post here, and i would like to share with you a small story in case you can help me.
          Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
          All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
          I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
          02-10-2024, 02:07 PM
        • mshone
          Lenovo thinkpad P1 G2 UUID and Serial number/mashine type unknown
          by mshone
          Sorry if topic if misplaced. Have lenovo thinkpad P1 gen2 with Xeon E-2276M CPU and NVIDIA® Quadro® T1000. It is a new board replaced. Old board was P1 G1 model with i7 and it is defective. I ordered a new one with xeon, but is gen 2. Laptop case is suitable for this motherboard, with some little difference (GPU fan and subcard).Ok, ordered and replaced and GPU fan and subcard and now laptop is working fine, but serial number and UUID is unknown. Ok, i readed several topics here and found Thinkpad maintenance disk, but.....which values to type? How to find data base with those values? serial...
          08-29-2025, 06:41 AM
        • Iherduleikgemz
          Dell Vostro 15 3568 15341-1 91N85 - Won't recognize battery and charger
          by Iherduleikgemz
          Hello everyone
          I have been working on this laptop mentioned in the title, it initially had a blown PQ4410 mosfet. After I replaced it and repaired the damaged PCB the thing started working again, but there is still another problem. The laptop won't recognize genuine battery and charger. I have 3.3v KBC PIN36 PS_ID and this is pretty much where my knowledge ends.
          Where should I go next? Replace the KBC or measure something else?...
          07-24-2025, 09:56 AM
