hardisk repair
  • klangsotan
    • Mar 2014
    • 45
    • indonesia
    hardisk repair
    haloo master
    can you help me
    how to repair hardisk can"t detect ...
    thanks a lot before
  • sopik78
    • Nov 2013
    • 517
    • Czech Republic
    Re: hardisk repair
    Is it problem of harddisc or laptop? Did you try the HDD in other laptop and did it work or not?
    What laptop do you have exactly?
    • Levi
      • May 2014
      • 59
      • Ghana
      Re: hardisk repair
      U need to come out clear and give details on the problem u r experiencing, then u can get help from pals on the forum.
      • mdchala
        • May 2015
        • 8
        • Algeria
        Re: hardisk repair
        you should test the hard disk outside the computer using sata-USB adapter.
        • stormanimal83
          Nintendo Switch picofly installed cause parental lock how to get Master Key for restoring OFW
          by stormanimal83
          i bought a use console from ebay fixed it and it has parental lock. seller wasn´t helpful and nintendo either cause they don´t support used devices as they told me per mail. thanks for the bad support here in germany. was totally upset as i read the answer to my mail from 1 week ago.... there was no other way to get rid of that code rather than modding the console cause i didn´t even had the device id as it´s a patched V1 and for getting masterkey on salthax there is the need to type in the device id which was unknown in this case... i did a mistake. after the repair i entered my wlan and...
          08-04-2024, 01:47 AM
        • The WABBIT
          Dell Inspiron 5559 need BIOS Master PW
          by The WABBIT
          I had recently purchased a used Dell Inspiron 5559 that I had found at a local pawn shop. And of course the system is locked. And I have no idea what the Admin pw is and I have no information for the previous owner.
          After many days of research I have found that this system, like many new system, require a Master PW/Code to unlock it or reprogramming of the BIOS.
          Contacting Dell Support was a waste of time. They won't give me the the Master PW/Code unless I have the information of the Registered owner that they have on file. They even gave me a link to a page on their...
          07-12-2021, 04:20 PM
        • 66Ton99
          Gigabyte Z790 Aorus Master Schematics Request
          by 66Ton99
          I have a problem with my Gigabyte Z790 Aorus Master, it doesn't run now.
          Looks like I damaged some elements
          But I do not know what's there.
          Please help....
          07-11-2025, 01:56 PM
        • sect-sin
          Gigabyte XT 6800 XT Aorus Master BIOS needed
          by sect-sin
          I have an AORUS MASTER RX 6800 XT (non USB-C version), and my problem is that FUSION RGB is not working, it is not finding the GPU, and the RGB lights are off. There is a new firmware on the Gigabyte site which is supposed to fix this exact issue, but their Firmware upgrade does not work (I just get the highly unhelpful Erasing Flash Failed message when trying to update). I tried various internet-recommended software fixes to address this, but nothing helped, the factory Gigabyte EXE refuses to flash the BIOS.
          My last resort would really be flashing the...
          10-13-2023, 06:08 AM
        • pabloroggeri
          Lenovo V360, no detect battery
          by pabloroggeri
          Hi friends!
          It does not charge or detect the battery. At first it didn't start, I programmed the BIOS with the file that is in this forum and it turned on but it doesn't detect a battery. I need to try another bios that is not the one that is already published in the forum, I suspect that the one I recorded is corrupt, or incompatible in some detail and that is why it does not detect the battery. I did all the measurements on the charguer integrated circuit and they are all ok. I think the problem comes from the data BUS side. It is for this reason that I need a different...
          07-28-2022, 08:18 AM
