i need a replacement -compatible- IT8586E LENOVO
  • kadi144
    • Aug 2015
    • 690
    • algerie
    i seek a compatible- IT8586E LENOVO
    LENOVO G50-70
  • fzabkar
    • Mar 2009
    • 772
    Re: i need a replacement -compatible- IT8586E LENOVO
    http://www.ebay.com/itm/Brand-New-IT...-/200993787483
    • PKTKS
      • Jun 2021
      • 5
      • Brazil
      Hi there seeking a compatible- IT8586E LENOVO as well
      but for LENOVO G50-80..
      Need to ask if someone tried one of those vanilla no branded
      chips to re-program them with EC bios and that worked ?
      Paul
      • Sametbey
        • Jan 2021
        • 229
        • Turkey
        You can follow two ways to change IT8586E. you can plug in the it8586e chip programmatically. or you can program it after plugging in with Svod programmer.
        I'm not happy to be so strong. because it's not humanly
        • PKTKS
          • Jun 2021
          • 5
          • Brazil
          thanks for the promptly reply..
          I have a RT809F (w/ extension PB board and cable..)
          I can save the old EC and program a new one with
          that .. although I have been just "buying" pre programmed
          chips for the price so far..
          But that is not best solution.
          There are a bunch of vanilla chips (not branded LENOVO)
          and.. my doubt is *IF* I can just put one there and
          re-program the chip hoping for the better...
          Paul
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            As long as the chip number is IT8586E, it works after programming. have replaced many many chips with success.
            • PKTKS
              • Jun 2021
              • 5
              • Brazil
              Thanks a lot... I was determined to order
              a bunch of vanilla batch to try them myself..
              I will now certainly ditch those branded ones..
              and try to use the normal chips..
              Can not figure out why LENOVO did that..
              But they fail at miserable rate...
              thanx
              Paul
              • martrah
                • Feb 2022
                • Estonia
                Where to get preprogrammed IT8586E for Lenovo E460 NM-A551?
                • tech_guru
                  • Nov 2018
                  • 44
                  • Greece
                  Do you know if FXS and FXA versions of IT8586E are interchangeable? Thanks
                  • jasko_jacker
                    • Oct 2014
                    • 1140
                    • italy
                    Use only chip branded lenovo
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      This is mixed bag. You can try but on some boards FXS/FXA are not compatible. Better to swap with the same suffix.
                      I've used IT8586E without the lenovo logo and it worked perfectly.
                      • coasterghost
                        Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                        by coasterghost
                        For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                        Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                        Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                        System Hardware:
                        Processor: AMD Ryzen 7 PRO 5850U
                        Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                        09-08-2025, 10:46 PM
                      • andrhouseolly
                        Lenovo X240 - motherboard replacement for X250, no image.
                        by andrhouseolly
                        Friends. I beg you to help me in this situation.
                        Lenovo X240 with a video problem. Native Intel drivers are not installed,
                        after installation, a black screen. It works with the standard Microsoft driver.
                        Understanding that there are problems with the video core,
                        I ordered a motherboard from Lenovo X250.
                        The laptop turns on, starts up, there is no image on the internal display.
                        The image is output to the external monitor.
                        I ordered another motherboard from Lenovo X250.
                        07-12-2024, 03:02 PM
                      • Grafnus
                        Lenovo ThinkPad P15 Gen2 Battery Mosfet Replacement
                        by Grafnus
                        Hey there,
                        first time posting here. I have been lurking a bit trying to find a solution but with little to no avail.
                        So I have a Lenovo ThinkPad P15 Gen2. When I got it (for free) it was turning on but not charging because the battery was unplugged. When I plug the battery in, the Laptop won't boot at all.
                        Specs:
                        • Type: Lenovo ThinkPad P15 Gen2 20YQ-001KGE
                        • CPU, GPU, RAM work fine (not involved in the Problem)
                        So the first thought was to toss the battery and get a new one, as clearly the BMS is throwing errors or something.
                        Now I noticed...
                        08-06-2025, 11:54 AM
                      • artvandalai
                        Where can I get compatible capacitor for replacement?
                        by artvandalai
                        Blew the capacitor on my analytical balance scale using the wrong power adapter. I need help finding a replacement compatible capacitor to buy. Will any 100uf 40v capacitor work as a replacement?
                        12-28-2024, 10:15 AM
                      • m4a2t0t
                        BD35231 compatible replacement
                        by m4a2t0t
                        Anyone know of a compatible replacement that has an adjustable output? The BD35230 has a fixed output of 1.0V and would be acceptable but I cannot find it anywhere. There is also the BD3523 which has an adjustable output but its also nowhere to be found. I could probably source them from alibaba but I dont have that much time and I dont want to make a huge order.
                        Or perhaps you know how the BD35231 can be modified to output 0.95-1.0V? The board does have empty pads for an adjustable IC but Ive only been able to make the output go up.
                        Thanks for any help...
                        08-28-2025, 08:32 PM
