HP Pavillion G6. no power
  • lorins_core
    BlackSmith
    • Dec 2012
    • 552
    • Philippines
    have a nice day to all.
    i Have repair hp g6 no power. if i plug the charger have no light indication. if i press the power on switch. the light indication blink then off, only if the battery inserted.
    i try to measured the voltage.
    i have a good unit to trace and i swap this parts i circled green
    can you check
    Same Problem...
    Help me how to fix this
  • mitu_sharma
    • Jul 2015
    • 182
    • india
    Re: HP Pavillion G6. no power
    flash u13 bios it will work
    • lorins_core
      BlackSmith
      • Dec 2012
      • 552
      • Philippines
      thanks i'll appreciate your answer.
      how can i to that? can you teach me step by step
      • lezsimply
        The Wanderer
        • 655
        • Philippines
        do you have a bios programmer? you need to remove chip from the board then flash it on programmer.
        • lorins_core
          BlackSmith
          • Dec 2012
          • 552
          • Philippines
          thank you pare... for your thinking of this problem it is a bios problem or hardware?
          can you give me the best solution for this. teach me how please.
          thanks again
          • lezsimply
            The Wanderer
            • 655
            • Philippines
            Whenever I have an HP or Compaq laptop with charger indicator the does not lit, first I do is flash bios with proper dump file. You should try that first.
            If not try to touch charger IC (PU9) and 5v/3v regulator IC (PU3) if its heating up. If it does there's a short somewhere.
            • lorins_core
              BlackSmith
              • Dec 2012
              • 552
              • Philippines
              in this case. i all ready to change the PU3 and PU9. i have a available unit same as this model. i swap both parts then i test. the good one still okey booting up. but the one have problem it a same.
              btw: the IC (PU9) and (PU3) not heat up...
              but i notice this parts i try to Trace this on may Voltmeter analog. wait i edit...
              • lorins_core
                BlackSmith
                • Dec 2012
                • 552
                • Philippines
                This is a good and working one. i test the voltage of 2 parts
                show up this
                Prove set 10v Voltmeter. tap the black on GND then The red inject to pins 1- 2 -3
                PQ44
                pin1 - 0V
                pin2 - 0V (gnd)
                pin3 - 2V
                PQ45 mosfet
                pin1 (S)- 3V
                pin2 (G)- 2V
                pin3 (D)- 3V
                see below
                here's the prove check board have problem
                PQ44
                pin1 - 0V
                pin2 - 0V (gnd)
                pin3 - 2V
                What happen to this? PIN1(S) and PIN3(D)
                PQ45 mosfet
                pin1 (S)- 0V
                pin2 (G)- 2V
                pin3 (D)- 0V
                how to ix this?
                • mitu_sharma
                  • Jul 2015
                  • 182
                  • india
                  hi lorins
                  tell me one thing. you will check voltage on pin no 20 on pu2 (19v)
                  and pr94 near pu3 it has also get 19v, pr62 4.62v if all the voltages are ok then check
                  3.3v on u13 at pin no 7,8. if avail flash the bios
                  • lorins_core
                    BlackSmith
                    • Dec 2012
                    • 552
                    • Philippines
                    hi lorins
                    PU2- pin check pin 20 = 19V
                    Pr94- 0v
                    pu3= what pin i check
                    u13=?
                    thanks
                    • lorins_core
                      BlackSmith
                      • Dec 2012
                      • 552
                      • Philippines
                      i notice again the +5VPCU?
                      or Missing the Supply of this type of Supply +5VPCU
                      where the location of this source...
                      • atsio
                        • Oct 2013
                        • 819
                        • Greece
                        Wait. I think you started the wrong way.
                        When you want people to help you write the model of the board and if you have a schematic share it or point to the location of it, Mitu Sharma probably is looking at the wrong schematic and gives you wrong information.
                        Mitu Sharma and Lezsimply, lorins core described in his problem that when he attaches the battery and presses the power button the light indication blinks (that is the laptop tries to start) which in my opinion has to do with a short somewhere and not bios.
                        I will never advise a person to flash the bios before i had checked that everything is ok (I have always voltages and the ec controller functions) and I do not have data signals from the bios ic (although in this situation may be a faulty chipset - very rare) or the laptop starts but it fails to boot (although in this situation may be again a faulty chipset).
                        I got sick of seeing people asking for bios dumps. Flashing the wrong bios or a bad bios file may make the problem more complicated.
                        Check pins 8 and 17 of PU3 and PL21, PL20 for resistance relative to ground without power plugged in and voltage when you plug in the adaptor.
                        • mitu_sharma
                          • Jul 2015
                          • 182
                          • india
                          you are right atsio
                          i am looking wrong schematic
                          sorry for that .
                          lornis please send me proper model no of motherboard
                          • lorins_core
                            BlackSmith
                            • Dec 2012
                            • 552
                            • Philippines
                            PU3
                            PIN 8- 50ohms (5ohms X10 selected) Analog type ohmmeter
                            PIN 17- 60ohms (6ohms X10 selected) Analog type ohmmeter
                            Coil
                            PL21-1.9 OHM read X10
                            PL20- 1.9 OHM read x10
                            Thank Mr.Atsio
                            unit model Hp G6
                            mobo : DA0R12MB6E0
                            • atsio
                              • Oct 2013
                              • 819
                              • Greece
                              Do you have any voltage on these points (pins 8 and 17 of PU3 and PL21, PL20);
                              • lbslakmal
                                • 47
                                • sri lanka
                                I have G6 R33 motherboard... when i connect adapter plugging light on....after few second charging light (Orange led) on..that time battery already removed. after few second ...again pluggin light blinking few times and off...
                                • lorins_core
                                  BlackSmith
                                  • Dec 2012
                                  • 552
                                  • Philippines
                                  if battery inserted and plug the charger, then press power on switch the light indicating on charging terminal white light 3 times light and off the light.
                                  but i notice have no light on charging terminal white light or orange. no indicating charging.
                                  • atsio
                                    • Oct 2013
                                    • 819
                                    • Greece
                                    I repeat? Do you have any voltage on these points (pins 8 and 17 of PU3 and PL21, PL20);
                                    • lorins_core
                                      BlackSmith
                                      • Dec 2012
                                      • 552
                                      • Philippines
                                      sorry to late post
                                      PU3 Reading
                                      PIN8 - 0.9V
                                      PIN17- 0V
                                      PL20 - 0V
                                      PL21 - 0V
                                      What can I Do to next step MR. Atsio. Thank and Advance
                                      • lezsimply
                                        The Wanderer
                                        • 655
                                        • Philippines
                                        @atsio yeah you're right. I missed the battery part.
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • ipatch
                                          troubleshooting microsoft surface pro 4 no power no led charge light
                                          by ipatch
                                          hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                                          10-05-2023, 11:59 AM
                                        • russpall
                                          LG 39ln540v - red light flashes twice, no power to LED driver?
                                          by russpall
                                          Hi there,
                                          I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
                                          The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
                                          08-27-2024, 01:07 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          Laptop computer that went completely dead no boot no power light no hard drive light
                                          by sam_sam_sam
                                          See pictures for type of laptop computer
                                          I checked switching power supply brick 19.2 volts multi meter only
                                          No booting without switching power supply connected
                                          Checked switching power supply with an (28 volt ) incandescent light bulb it lights then hooked up the switching power supply again now the laptop and boots like normal
                                          What the heck is going on here...
                                          04-04-2025, 04:58 AM
