W812DI1 plugged but not charging...
  • mista
    • Apr 2015
    • 92
    • belgium
    hi guys i need some help i have a laptop with a problem th ac plug is connected but the battery not charging any idea ?
    thanx for help
  • mista
    • Apr 2015
    • 92
    • belgium
    Re: plugged but not charging...
    Someone for help ?
    Thanx
    • mista
      • Apr 2015
      • 92
      • belgium
      Someone for help?
      Thanx
      • pacoreo_com
        • Apr 2015
        • Indonesia
        check P-Channel mosfet in charging circuit
        • ala_borbe
          aka Donald
          • 1625
          • Malta
          try another working battery
          Im Back... sort of...
          • mista
            • Apr 2015
            • 92
            • belgium
            hi guys thanx a lot for your advice please pacoreo can you explain to me how can i check p channel sorry im a newbie in electronic i dont have another battery can i check with multimeter ?
            thanx a lot
            • dj_ricoh
              • 2073
              • uk
              It is the battery.
              Replace it.
              • mista
                • Apr 2015
                • 92
                • belgium
                Thanx Guy DJ ricohhh i will check
                • polytek
                  • Dec 2013
                  • 496
                  • TUNISIA
                  thanx for help
                  what laptop exactly dell or hp or what ?
                  i have seen the problem with dell inspiron 1545 plug in not charging; try with 2 battery no succes,try another dc adaptor, update bios no result, change dc jack problem was solved.
                  • mista
                    • Apr 2015
                    • 92
                    • belgium
                    ok friend yeahhhh i find the slot to connect the ac plug moves a little bit up and down
                    my computer is w812DI1 pointer someone know about this computer some wiring diagram?
                    please tell me polytek did you test with multimeter your dc jack? or it s was disconect from the motherboard?
                    thanx for help
                    • mista
                      • Apr 2015
                      • 92
                      • belgium
                      anyone has the wiring of this laptop w812DI1 ?
                      thanx a lot for help
                      • polytek
                        • Dec 2013
                        • 496
                        • TUNISIA
                        change the dc jack, it's easy you can work without schematic, if you need schematic; this link:
                        • mista
                          • Apr 2015
                          • 92
                          • belgium
                          Thanx a lot polytek about battery how can i check it if its not the battery
                          • dj_ricoh
                            • 2073
                            • uk
                            its simple!
                            you do this on daily basis? you buy the battery.
                            if the the battery its ok then you got another battery to sell it.
                            if not, you got 2 battery to use
                            to check the battery you need diagram from battery to force the battery to charge to enable some pins inside, then some kaka resistor bleeeeeeeaaaaaaaaaaa.
                            just buy a battery!
                            i`ll make you special pictures sunday if i don`t forget with a DV6 batteries MSG :not detected, plug in not charging, charging(in fact NOT charging) and ofc working.
                            same notebook just a pile of those crap batteries
                            • mista
                              • Apr 2015
                              • 92
                              • belgium
                              thanx a lot dj ricohhhhh i will wait for your pictures
                              sorry what does it mean ofc ?
                              thanx for help
                              • mista
                                • Apr 2015
                                • 92
                                • belgium
                                i didn t find yet a battery for the laptop w812DI1 someone can advice me ?
                                thanx a lot
                                • mista
                                  • Apr 2015
                                  • 92
                                  • belgium
                                  anyone ?
                                  • mon2
                                    • 14369
                                    if you can change then you should be.
                                    Good advice. Thanks 👍
