HP 840 G5 shows orange charging LED and shows charging icon in windows without battery connected.
  • Zibbo
    • Mar 2017
    • 203
    • Zimbabwe
    HP 840 G5 board number 6050A2945601 says "charging" in windows without battery connected. The motherboard looks clean visually, no signs of liquid damage no burnt or missing parts. I have not come across such an issue and I am requesting assistance on where to start troubleshooting.
  • mon2
    • 14633
    On the battery connector is a pin that alerts the battery charger that the battery is attached or is not. Usually is an active low signal so if this pin is ‘0’ state or 0 volts, battery IS attached. Vice-versa is battery is absent.
    Confirm the voltage to ground of the pin on the battery connector. Maybe this pin is missing the pull-up resistor to park this signal line to ‘1’ state when the battery is absent.
    • Zibbo
      • Mar 2017
      • 203
      • Zimbabwe
      Originally posted by mon2
      On the battery connector is a pin that alerts the battery charger that the battery is attached or is not. Usually is an active low signal so if this pin is ‘0' state or 0 volts, battery IS attached. Vice-versa is battery is absent.
      Confirm the voltage to ground of the pin on the battery connector. Maybe this pin is missing the pull-up resistor to park this signal line to ‘1' state when the battery is absent.
      Thank you mon2 but on this particular model the battery connector only has 4 connections, positive, negative and smbus.
      There is 12v on positive and 3.3v on the 2 smbus lines.
      • piernov
        • Jan 2016
        • 4437
        • France
        Battery is internal, it is not supposed to be removed, so that's a non-issue to me.
        • Zibbo
          • Mar 2017
          • 203
          • Zimbabwe
          I have also noticed that it says "53 minutes remaining to full charge" with or without battery and the battery volatge does not increase.
          • Prosatanosz
            • Nov 2015
            • 108
            • Hungary
            Battery is dead. Asus, Dell, the same thing.
            • Zibbo
              • Mar 2017
              • 203
              • Zimbabwe
              Its a good battery, I have tested it on another laptop
