short 1.1 V_S5
  • klangsotan
    • Mar 2014
    • 45
    • indonesia
    short 1.1 V_S5
    hai master ....
    i hope you can help me ....
    my acer code board ZQP REV :C
    3V and 5V is Ready
    indicator charger is on
    but if i TURN ON POWER indicator charging is off and machine is daed so 3V and 5V is lose
    I was chek PL11 is short
    please tell me for this case ....
    thanks a lot before
  • meritosari
    • Oct 2010
    • 774
    • Indonesia
    Re: short 1.1 V_S5
    you should remove PL11, then check the pad, which side on pad still shorted, direct to IC or to Load.
    anyway how many ohm you mean PL11 rail was shorted
    • highpulse
      i hate HP
      • May 2013
      • 1488
      • portugal
      Re: short 1.1 V_S5
      how did you crossed info mentioning 1.1 line rail is in short ?
      • DynaxSC
        Extreme High Current & Low Voltage Short Killer ??
        by DynaxSC
        Hi Folks
        I'm looking for a extreme high current short killer solution for a reasonable cost.
        I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
        After taking off the socket, the shorts dissappear again.
        The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
        10-15-2024, 10:13 AM
      • Stephen
        MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
        by Stephen
        I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
        02-06-2025, 12:03 PM
      • Victor Moreira Silva
        Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
        by Victor Moreira Silva
        I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
        Well, my decice specs are the following:
        Model: Acer Nitro 5 AN517-54-55T5
        CPU: Intel Core i5-11400H
        GPU: NVIDIA GeForce GTX 1650
        Motherboard: GH51G LA-L181P Rev:1c
        The symptom:
        When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
        05-26-2025, 10:49 AM
      • aaronkatrini
        Help me find the short circuit on this WORKING Nvidia GTX1650
        by aaronkatrini
        Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
        Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
        04-18-2024, 03:15 PM
      • Geeker007
        9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
        by Geeker007
        Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
        I am new to electronics repair, so my queries could be naive but I am ready to learn.
        So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
        01-28-2025, 03:31 PM
