Toshiba L650D turns off after 6/10 seconds
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Have this in for reballing. After reballing NB it shows video but powers down by itself after 10 seconds if the keyboard is connected, 6 seconds if it is unplugged.
    It used to shut down before reballing too, when it was showing no video. It gets to BIOS if i am quick enough, it will even boot from the HDD.
    It also turns off by itself with no RAM, even with no CPU. Exactly same thing in every situation, shuts down after 6 sec without keyboard, 10 sec with keyboard. Regardless of everything else. It will stay on maybe 1 second longer if i'm mashing the keys in the meantime.
    I would replace KBC. In fact i would've already done that, just that i didn't have one handy and we'll have to order it. Any other ideas? I have a 100MHz digital oscilloscope to use now.
    A working TV? How boring!
  • looofy
    • Jul 2015
    • 34
    • sudan
    Re: Toshiba L650D turns off after 6/10 seconds
    is'n it a thermal shutdown signal ?
    • looofy
      • Jul 2015
      • 34
      • sudan
      winch platform ?
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        Board is Inventec MAS10AD. It can't be thermal, unless the thermal diode in the NB has crapped itself somehow. This board is one of the few that DOES have thermal sensing for the NB too... But i will measure and report back. I do have spare chipsets.
        • looofy
          • Jul 2015
          • 34
          • sudan
          here
          • looofy
            • Jul 2015
            • 34
            • sudan
            if the power was stable before the reballing then it maybe one of the legs NB_THERMD_P or NB_THERMD_N not soldered
            or there is a Leakage in NB_PWRGD signal in D4505 resulting Leakage in VCC_NB_PWRGD to the kbc
            • gcomputers
              • Apr 2013
              • 509
              • Albania
              Check the power button?
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                • Romania
                Power button is fine. It was shutting down before reballing as well, i have already mentioned that.
                • looofy
                  • Jul 2015
                  • 34
                  • sudan
                  any progress ?
                  • kc8adu
                    • Nov 2003
                    • 8829
                    • U.S.A!
                    fan tach not being detected?
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      • Romania
                      I have this on my backlog, there are a few more that are urgent, this one can wait.
                      I've found a KBC and will try swapping that if all else fails, i have yet to check the thermal sensors. I doubt it's that, as the fan starts at "off" and only spins up a little bit before the laptop shuts down. But i will check the sensors before replacing KBC.
                      • fddizon
                        • Sep 2011
                        • 555
                        • Philippines
                        often times, shutdown is caused by shorted rails on power distribution.
                        check vs voltage rails
                        • Th3_uN1Qu3
                          Believe in
                          • Jul 2010
                          • 6031
                          • Romania
                          All power supplies ok, until it shuts down that is. Here's an update:
                          Fan tach signal checks out ok, thermal protect is not operating. U6001 does not receive the THRM_SHUTDWN# signal. 3.3 and 5v remain stable at all times - if it went into thermal shutdown, those rails would shut down as the output of U6001 is tied to the enable signal of the 3.3v and 5v PWM.
                          Replaced KBC: same behavior
                          Flashed BIOS: same behavior
                          Heated the SB a bit: same behavior
                          This board's stupid...
                          • Th3_uN1Qu3
                            Believe in
                            • Jul 2010
                            • 6031
                            • Romania
                            Replaced Southbridge today. IT'S STILL DOING IT.
                            • twonk9098
                              Lenovo Legion 5 high fan spin turns off after 34 seconds
                              by twonk9098
                              I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
                              I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
                              I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
                              I have tried a few new bios but exactly...
                              07-14-2024, 11:19 AM
                              09-06-2024, 05:27 AM
                            • Rick_1234
                              LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                              by Rick_1234
                              Good evening, gentlemen.
                              I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                              To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                              https://drive.google.com/file/d/1L6S...ew?usp=sharing
                              Things I tried
                              - Bought a new AC adapter thinking that was the problem but the problem...
                              06-22-2024, 04:44 PM
                            • Kambi13
                              Dell Inspiron 3542 Turns on works for 30 seconds to 1 minute then turns off
                              by Kambi13
                              Hi all need some help, I've got a Dell insprion 15 3542 that turns on works for about 30 seconds or sometimes a minute or two and then turns off and wont turn on again until I remove and replug the power connector
                              Not heat related, everything is ok regarding to that.
                              All voltages are present.
                              Wondering if this as anything to do with one wire circuit, the charger is not original, but it was working fine
                              Motherboard is Cedar 13269-1 F3XMC Rev A00...
                              07-12-2024, 06:10 AM
                              09-06-2024, 05:59 AM
