video chipset. reball or Replace??
  • ry x hunter
    • Jun 2013
    • 184
    • philippines
    hi guys i need an advice on how to decide if the video chip of a laptop need to reball or need to replace.. and how do i know if the video chip is already damage?
  • ravi_1617
    YY Solutions
    • Jan 2012
    • 343
    • India
    Re: video chipset. reball or Replace??
    First reflow gpu chip.if display comes just for testing purpose reball it.otherwise chances are you have to replace it.
    • sopik78
      • Nov 2013
      • 517
      • Czech Republic
      Don't do reflow at all, don't stress the chip more than you need, reflow will work in minor cases even if the chip could work after reball.
      Just try reball, if it will not work, try change for other chip, that's it
      • atsio
        • Oct 2013
        • 819
        • Greece
        I mentioned it before and I will again. If the chipset is not shorted most of the times it is good for a reball. The main problem is not the chipset but a deformed board due to long exposure of board and plastics that support it to excessive heat.
        A lot of times I come across even and to deformed chipsets.
        • ry x hunter
          • Jun 2013
          • 184
          • philippines
          sir how can i check if the chipset is shorted?
          • atsio
            • Oct 2013
            • 819
            • Greece
            By checking its power lines.
            • othello301
              • Jul 2015
              • Greece
              check power lines of chipset
              • masud
                • Jul 2011
                • 317
                • Bangladesh
                which bga reballing machine would be best considering reasonable price.
                • rookieme
                  • Oct 2014
                  • 396
                  • Greece
                  In my opinion any machine around or above 1000$ will serve you well.
                  • senchire
                    • Dec 2012
                    • 190
                    • Bosnia
                    To be honest, if you are into some practice DIY machine can be better and more long lasting then cheap IRDA machines, just my 2 cents.
                    P.S: Doing reballs with Preheater and hotair station 2 years and can do it 100% right every time .
                    • acedogblast
                      by acedogblast
                      11-02-2024, 05:13 PM
                      Common SPI bios chip programming Questions and Answers
                      by SMDFlea
                      Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
                      A: If you can`t read from it how do you expect to write to it ?.
                      Q: Why is my bios chip unreadable ?.
                      A: The programmer is faulty or has a worn or broken zif socket.
                      The USB cable is frayed,connector pins worn or some other physical damage.
                      Not enough amperage or voltage to power the programmer properly.
                      Bad...
                      09-02-2021, 04:40 PM
                    • Jeroentje
                      Asus X571GT repair chip replace and tips wanted
                      by Jeroentje
                      Hi
                      I try to repair a asus Asus X571GT (DA0XKTMB8C0) no power no lights.
                      I saw a burned (small hole in it) chip (JW10F) proberly a TPS22976DPUR, I removed it, now with power connected the laptop turns on and direct off again, power led and fn will light up.
                      I found on a donor lenovo board a G2898KD1U (wa9y), looks the same ..
                      Result is still the same, turns on and direct off again, first attempt is with backlight on all other direct attempts are only the power and fn led.
                      Could it be the chip is to diffrent to make the laptop work again ?
                      04-28-2024, 10:59 AM
                    • Troystain
                      Help EZP2023+ updated chip database for w25q256jveq?
                      by Troystain
                      Hello, anyone here have updated ezp2023+ chip database in .dat file format.
                      I need to add w25q256jveq chip but I do not know what data should I type.
                      I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
                      The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
                      11-25-2024, 12:53 AM
                    • inck243
                      Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
                      by inck243
                      Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
                      The BIOS...
                      07-25-2024, 09:17 AM
