HP G62 AMD keeps freeze after reball
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Hello. Have this one HP G62 UMA. have bad balls so realled it. but after reball it keeps freeze. so i replace NB but it keeps freezing too. so i reball SB ut nothing changed.
    im out of ideas
  • dj_ricoh
    • 2073
    • uk
    Re: HP G62 AMD keeps freeze after reball
    cpu? cpu socket?
    check for short under with cpu and without
    • gcomputers
      • Apr 2013
      • 509
      • Albania
      Try to flash bios.
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3627
        • slovakia
        with that freezing i mean it work ok for 10min and than freeze. after restart again
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3627
          • slovakia
          guys any advice?
          • Agent24
            I see dead caps
            • Oct 2007
            • 5065
            • New Zealand
            Bad ceramic capacitors around the chip? Bad chip supply voltage(s)?
            -David VanHorn
            • Stanley1843
              BEST 505 Vs Mechanic Brand Reballing Balls with Lead
              by Stanley1843
              has anyone use these Brands of solder balls? The brand BEST writes on the label of the jar the specs of the solder balls instead of the Mechanic brand. I beleive that BEST brand must be more professional (in labeling at least) but I have never try one of them so I would like your opinion. By the way I hardly can I find the Mechanic brand in aliexpress (the only where I found was lead free solder balls) and on ebay these that I found are approximately15USD per jar. If you know any other trusted brand of solder balls please tell me.
              06-22-2024, 11:06 AM
            • CornholioGSM
              Macbook Pro 15" 2018(820-01041-A) Freezing, Rebooting, Kernel Panics but only with connected Battery
              by CornholioGSM
              I have here one interesting problem.
              Laptop comes to me with freezing and rebooting problem. All inside was relatively clean and no water damage. Only visible problem was one swolled cell on battery...all was looking like batt problem.
              I have put inside new - not original batt, but problem with freezing still. I am able to boot into os, then pc can run few seconds, then freezes and reboot and reboot until force power off.
              Quickly i am able to see battery information...batt is detected normally in os with power cycles hours...
              06-25-2024, 12:27 PM
            • maleksa
              Yamaha MOX8 boot freeze and distorted sound
              by maleksa
              My Yamaha MOX8 synthesizer recently developed two issues.
              Firstly, after booting up, it operates as normal. However, after about 5 minutes, the sound starts to get distorted (broken up screeching sound) almost like putting it through a guitar distortion pedal. After a while, the distorted sounds will go away for a while and comes back. At times, the synthesizer will also freeze I need to power off and on again.
              Secondly, when powering off and on again, there will be times where the synthesizer will freeze during the boot sequence (freezes at the MOX8 Opening Screen),...
              11-07-2024, 03:28 AM
            • corrize
              What are the 2 or 3 most used BGA balls sizes please ?
              by corrize
              Hello, I want to buy BGA balls (not stencils, only balls) but I don't know what size, it's just for reballing the new chip balled if the first attempt fail. So I will rarely use it. Probably chips are PMIC with max 60 balls. I don't need to reball EC chips from laptops of big chips like that.
              So what are the 2 or 3 most used BGA balls sizes I should have for cover the jobs please ?
              05-09-2024, 02:18 PM
            • EsIstSimon
              Lenovo Ideapad 5 15ARE05 random freeze
              by EsIstSimon
              Hi there,
              i have a Lenovo Ideapad 5 15ARE05 that will freeze randomly.
              Sometimes it wont even post, sometimes i can use it for a couple seconds or minutes before it completely freezes.
              Sometimes the screen freezes, but still displays the last frame, sometimes (pretty rare) the screen goes black
              It does not matter what i do. Installing windows, starting Fedora or just sitting in the bios. After some time it will freeze.
              When the freeze occurs, the laptop draws a pretty constant wattage (it will just stay on the value that it draws, when it locks...
              12-21-2022, 03:03 AM
