lg nexus 5 water damaged solution?
  • mista
    • Apr 2015
    • 92
    • belgium
    hi everyone i need to know how can i repair a water damaged for an lg nexus 5 ? alla adivce are welcom
    thanx a a lot
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: lg nexus 5 water damaged solution?
    First I'd try putting it in a tub of rice for a solid 48 hours.
    • diif
      • Feb 2014
      • 6978
      • England
      Strip and clean with alcohol first. Then put in the rice.
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3627
        • slovakia
        that is 100% giude how to kill a board
        • mista
          • Apr 2015
          • 92
          • belgium
          hi everyone thanx a lot for the answer
          ktmmotocross can you advice to me something ?
          thanx a lot
          • imgaurav86
            • May 2008
            • 35
            The first thing you need to do is strip the board and dry it completely. You can either put the board under the good sun for few hours or you can strip all the plastic parts off the board and put it close to 100w watt lamp (make sure you don't put it to close). You can put it into the electric oven as well and bake it on 80 degrees for 10 minutes (No microwave).
            Do a visual inspection and check for any corrosion around the connectors. You can use a toothbrush and isopropyl alcohol or methlated spirits.
            Make sure you dry it completely before you attempt to turn it on otherwise it will destroy the POWER IC.
            If this didn't fix it then look for further instruction on checking short circuit and Power management chip.
            • mista
              • Apr 2015
              • 92
              • belgium
              ok imgauray86 thanx a lot for the answer i will try it someone have the schematic about the lg nexus 5?
              • RetroComputingGrotto
                Water Damaged Toshiba 48L1435DB
                by RetroComputingGrotto
                I have a water damaged Toshiba TV that was hanging nicely on the wall then over the summer we had a new multi-million pound boiler system put in and right where this TV was hanging is a nice new pair of water pipes for the radiators...
                The TV hasnt been used for a fair few months but it was needed again the other day and needless to say, it didn't power on or show any signs of life (no standby LED etc). After checking the fuse in the plug (and that the socket it was plugged in to worked) I decided to get up some step ladders to take a closer look and low and behold! It looks like...
                10-07-2024, 08:23 AM
              • rzsn
                water damaged G513I
                by rzsn
                Hello friends, so I have got a "water damaged" (or cola/beer/coffe .. something dark and sticky) G513I system - which has the board and schematics from this thread. After cleaning up all the visible sticky residue with water and detergent (thankfully mostly on the top/keyboard side), I have a partial success. IPA was of no use for cleaning this.
                Using a bench power supply on the DCIN jack (as it seems that the PSU keying pin is not wired at all - series resistor R6003 is not populated), and using a shoring wire for the power button (either pin 5 on CN251 keyboard, or one...
                12-22-2024, 09:02 PM
              • phantomEVO
                [help]820-01521 WATER DAMAGED
                by phantomEVO
                HELP! audio board+its flex+powerbtn flex water damaged (an hole on audio board)!!! chnged both, but i have 5v on both ports:
                https://files.fm/f/6gjpqyjw3q
                here some measurements
                ppbus_g3h 12,29v
                PP3V3_G3H 3,29v
                pp3v3_upc_xa_ldo pp3v3_upc_xb_ldo 3,27v
                PP1v8_UPC_XB_LDOD PP1v8_UPC_XA_LDOA 1,8v
                PP1v8_UPC_XA_LDOD PP1v8_UPC_XA_LDOa 1,8v
                PP1V1_UPC_XA_LDO PP1V1_UPC_Xb_LDO 1,1v
                with battery connected, as soon as i connect the cable, i see direclty 20v, but stuck at 0,0250
                10-24-2025, 04:23 AM
              • estabilito
                Dell Latitude E5590(La-f411p) water damaged
                by estabilito
                I have water damaged Dell Latitude E5590 around charging ic.
                Laptop was dead but i replaced some components like capacitors, resistors, resoldered charger(intersil 9538h) but traces under PQ904 dual mosfet(AOE6936) was burnt.
                I rebuilt traces and both mosfets(PQ904 and PQ905) and after all this work laptop started turning on.
                I dont have battery so i want to be sure if laptop behaviour is normal before buying.
                On PL902 i have weird voltage around 5Volts, on battery socket voltage looks normal - 13.5v.
                Is this voltage on pl902 normal?...
                03-08-2025, 06:22 PM
              • abajor
                A2141 820-01700 Water Damage L8504 Damaged, U3100/U3200 power cycles UB300/UB400 5V .25A
                by abajor
                Like title says A2141 came in with Water Damage, customer desperately wants the data.
                The actual water ingress doesn't appear too bad it sat for a day but was very dusty internally. I have no idea why L8504 was arced there is no apparent moisture there or around the LVDS cable; however, the LVDS to screen screw studs had popped off at some point and somebody tried securing it with kapton tape.
                I had to create a micron wire pad jumper to reconnect the south side of the L8504 since the primary pad was blasted down to the vias.
                That said after cleaning up the...
                12-21-2024, 07:16 PM
