How to troubleshoot fault with SATA detection
  • wibble
    • Jan 2011
    • 31
    Hi, just thought I would try this forum in case any one had some experience of this issue.
    The machine is a Toshiba Satellite L500 (core i3).
    Fault is ; no HDD detected in BIOS. Does not detect HDD on boot/ However, the internal optical drive is detected.
    Just for clarity, the problem is not a faulty HDD, it appears to be something with the motherboard. As I see it, could be either (a) southbridge chip bga problem; (b) BIOS corrupt; (c) bad SATA connector or faulty smt cap / resistor between connector and southbridge (South Bridge: ICH9-M)
    Or perhaps its something else I have not thought about.
    Does anyone know if there is some software I could use, presumably booted from a CD, which could check the ICH9 bus itself. Or, is there a known common fault with these chips, etc.
    Thanks.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: How to troubleshoot fault with SATA detection
    I'd check the connector and BIOS settings before the more complicated stuff.
    • hansie55
      • Dec 2013
      • 254
      • Netherlands
      In my case it needed a bios update. (Bios was never updated yet since delivery.)
      Newer HDD's seem to need other bios settings.
      • SteveNielsen
        Retired Tech
        • 2327
        Remove the optical drive and test with just the HDD drive. Sometimes a bad optical drive can cause such symptoms.
        • atsio
          • Oct 2013
          • 819
          • Greece
          Thanks.
          If intel PCH ibex peak, it is a well known problem with recognizing sata hdd's (errata 21)
          • DynaxSC
            GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
            by DynaxSC
            I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
            There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
            The board is generally working now, all PCIe ports are working, Windows installs normally.
            However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
            The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
            03-10-2025, 12:27 PM
            HP Z2 G4 + 3TB SATA 6Gb/s 7200 HDD i7-8700K Specification for Upgrade or Repair
            This specification for the HP Z2 G4 + 3TB SATA 6Gb/s 7200 HDD can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z2 G4 + 3TB SATA 6Gb/s 7200 HDD boardview and Z2 G4 + 3TB SATA 6Gb/s 7200 HDD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
            09-12-2024, 03:28 PM
          • clabr
            Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
            by clabr
            Need help to solve some problems with this laptop.
            After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
            After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
            Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
            Before this had happened I observed some other problems:
            When I tried replacing original mecanical HDD with a SSD HDD could not get them...
            12-02-2021, 08:09 AM
          • Rictech
            Panasonic SA-MAX770PU SMPSU board fault....
            by Rictech
            Hello everyone. 😀
            As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
            Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
            Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
            This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
            There are no devices that have exploded or otherwise show signs...
            08-26-2024, 01:05 AM
          • howardc64
            Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
            by howardc64
            • Prior owner tried a replacement main board. No difference.
            • Samsung 2x red blinking standby LED = panel fault
            • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
            • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
            • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
            07-19-2025, 10:54 PM
