Lenovo G780 no power at all :(
  • Cyber01001
    • Apr 2012
    • Croatia
    Turned off itself after 15-20 min of work,didn't overheat,cpu cooler almost without dust! No led ,no power at all... anybody have idea what's wrong? I'm stuck
  • samanthban
    • Feb 2014
    • 253
    • Sri lanka
    Re: Lenovo G780 no power at all
    I got the same issue, customer has removed by him self for cleaning purpose once fix it back it stops after some time.Arranged for bench test, finally found one thermal pad was missing ,check obvious first .
    sigpic
    • Cyber01001
      • Apr 2012
      • Croatia
      You misunderstood me!
      Laptop has no power at all,voltage comes to the board, ,there are no visible damage anywhere.
      PQ301,PQ302,PR302 have voltage...i cannot find what's wrong on the board
      Voltage on power switch connector is something about 0.2v :/
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3627
        • slovakia
        so u dont have 3.3v
        • Cyber01001
          • Apr 2012
          • Croatia
          no, i dont.
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • PantherDave
            by PantherDave
            Hi all!
            05-29-2024, 02:01 PM
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
          • Mita99
            Lenovo Thinkpad P72 EP720 NM-B723 MB - Power disabled within 2 seconds after plugging the charger
            by Mita99
            Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
            Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
            Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
            04-27-2025, 07:20 PM
          • Dr.d
            Help please..Lenovo ideapad 5 14itl05 power and charging problem
            by Dr.d
            I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
            Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
            04-05-2024, 11:48 AM
