Lenovo G555, only external display working
  • atsio
    • Oct 2013
    • 819
    • Greece
    Re: Lenovo G555, only external display working
    You can check them with multimeter in diode mode.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3610
      • slovakia
      sorry NB.
      • HarryPK
        • Mar 2014
        • 210
        • barabai
        in my case. i have toshiba with ati gpu. work with external disply likes your. i chnged bios ic and reprogram it. laptop normal again.
        • samanthban
          • Feb 2014
          • 253
          • Sri lanka
          its important to check clk+clk- before a further step??
          sigpic
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3610
            • slovakia
            but how to check? i dont have scope
            • Agent24
              I see dead caps
              • Oct 2007
              • 4981
              • New Zealand
              #26
              I don't think you could without one
              -David VanHorn
              • atsio
                • Oct 2013
                • 819
                • Greece
                #27
                You said you have checked GMCH_ lines when you have swapped NB. How?
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3610
                  • slovakia
                  #28
                  when it was removed i check lines
                  • atsio
                    • Oct 2013
                    • 819
                    • Greece
                    #29
                    How?
                    • ktmmotocross
                      Boardkiller
                      • Feb 2014
                      • 3610
                      • slovakia
                      #30
                      from pads under the ic to lvds connector
                      • atsio
                        • Oct 2013
                        • 819
                        • Greece
                        #31
                        I Know you did that but How? Continuity check?
                        • ktmmotocross
                          Boardkiller
                          • Feb 2014
                          • 3610
                          • slovakia
                          #32
                          yes.
                          • samanthban
                            • Feb 2014
                            • 253
                            • Sri lanka
                            #33
                            sigpic
                            • atsio
                              • Oct 2013
                              • 819
                              • Greece
                              #34
                              Usually lines on boards are checked in diode mode i.e. (lvds line check from Asus training manual)
                              Use multimeter to measure LVDS Con. Pin signal is correct of Diode value and compare with GOOD M/B.
                              Check LCDS Data signals,
                              LADATAP[0:2]
                              LADATAN[0:2]
                              Check LCDS Clock signals,
                              LACLKP/LACLKN
                              Of course, this way you do not have to remove GMCH.
                              • mferna14
                                Lenovo YOGA 910-13IKB cannot use External Display
                                by mferna14
                                Dear Friends., I am working on a Lenovo YOGA 910-13IKB. It is working fine, no problems at all. Today I was connecting to a External Display through the USB-C HUB, it could not connect. (This Lenovo model has only 2 USB-C Port, no HDMI, so has to be connected through a External USB-C HUB). I have changed the setting to External display but still no luck. Re-loaded Windows 11, assuming that the software might be faulty & still same. I know my USB-C port HUB is 100% good (HDMI, USBs, SD Reader) as I use this on all MacBooks & even my buddy has another HUB, still cannot connect to External...
                                08-16-2023, 07:58 PM
                              • ArchangelGabriel
                                Aorus 17G YD laptop, broken display, could not switch to external monitor
                                by ArchangelGabriel
                                Hello guys! I need a little help, I have one laptop for repair, it is an Aorus 17G YD, gaming laptop. Broken display, some cable ripped form daughter board connector, case broken, battery discharged and probably locked, etc. After I did the most tedious job I ever did on soldering back the broken cables (shielded cable) , I measured resistance on CPU and GPU core, 3 and 5 v ps and any coils I find on the board, everything seems to be fine. After I plugged the charger I don't get the power led light on from the charger connection maybe because the battery is locked , but on power button I have
                                11-23-2023, 03:55 AM
                              • lawrenceptrini
                                Lenovo Ideapad Flex 5 14ITL05 Only working on external display
                                by lawrenceptrini
                                Hi Guys,
                                LENOVO IDEAPAD FLEX 5 - 14ITL05
                                BIOS VERSION - FXCN24WW
                                EC VERSION - FXEC18WW
                                MTM - 82HT0004US
                                SERIAL NUMBER - R9130MDP
                                CPU - i7-1165G7
                                This laptop powers on but shows nothing on the internal display.
                                However, if I attach an external display it works fine.
                                Observations: When I shut down the laptop from windows,
                                the fan remains spinning until I close the lid. If I leave the lid open
                                the laptop will restart on it's own although I select shut down from windows.
                                Also, when I check the voltage on the...
                                10-15-2024, 12:47 PM
                              • Acnologia
                                Lenovo Thinkpad E15 Gen 2 NM-D011 - No display ? External , yes!
                                by Acnologia
                                Here is a pretty crazy one.
                                Step 1.
                                Laptop was brought to me as dead not working. Removed everything , cleared everything.
                                Step 2.
                                Some liquid damage close to the Type - C connector, and the connector even though it was cleaned wasn't charging the battery . Removed the Type-C port, and replaced it. Now the laptop turns on and charges battery. Shows external screen , not internal.
                                Step 3.
                                Took out the screen and checked it to a secondary Gen 2 i have, screen works like a charm.
                                Step 4.
                                Lets ,dive into the board. I see the edp cable on the...
                                05-07-2025, 07:16 AM
                              • plyanthony
                                Razer Blade 15 no external display with attached screen disconnected from motherboard
                                by plyanthony
                                Computer in question : Razer Blade 15 2020 Base Model
                                Model# RZ09-03286E22
                                BIOS CHIP: WINBOND W25Q128BV
                                What I'm trying to accomplish:
                                I want the computer to properly boot with an external display with the attached display disconnected from the motherboard. I have a CH341A programmer and full capability of modifying the BIOS easily. I Have tried various setting changes to no Avail.
                                What I've tried thus far: Too much to note and I really dont remember everything I changed but here it goes.
                                W/Stock BIOS - 1.06:
                                Disconnect the...
                                02-01-2023, 09:35 PM
