Lenovo G555, only external display working
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3553
    • slovakia
    Hello. Have this lenovo g555 with ATI igp. problem is that it display only on external. i replace aTI IGP with new working one but nothing changed.
    lid sw have power. it is UMA version
  • alihomee
    • Dec 2012
    • 1565
    • malaysia
    Re: Lenovo G555, only external display working
    check lcd cable or ur screen
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3553
      • slovakia
      cable checked, lcd changed
      • Life Goes On
        • May 2014
        • 264
        • Curacao
        Check the connector from the cable.
        The Night Drop Down, I Will Keep Try Until..., You Never know.
        Dushi Kòrsou, Nos Tei.
        • samanthban
          • Feb 2014
          • 253
          • Sri lanka
          please post here if you have the schematic.
          sigpic
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3553
            • slovakia
            here is schematic
            • atsio
              • Oct 2013
              • 819
              • Greece
              Please post voltages on lvds connector.
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3553
                • slovakia
                here is measurements of lvds connector
                • atsio
                  • Oct 2013
                  • 819
                  • Greece
                  You seem to have a problem with KBC. Try to inject 3.3v on the dac_brig pin.
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3553
                    • slovakia
                    i just replaced kbc but nothing changed. try to inject. what is dac_brig signal for?
                    • ktmmotocross
                      Boardkiller
                      • Feb 2014
                      • 3553
                      • slovakia
                      inject 3.3V but no change
                      • atsio
                        • Oct 2013
                        • 819
                        • Greece
                        brightness. Probably no enbkl signal.
                        • atsio
                          • Oct 2013
                          • 819
                          • Greece
                          Measure the signals on the screens lvds connector
                          • ktmmotocross
                            Boardkiller
                            • Feb 2014
                            • 3553
                            • slovakia
                            rightness is regulated from UMA_PWM. ENBL signal is for VGA
                            • atsio
                              • Oct 2013
                              • 819
                              • Greece
                              I just noticed that you have an 15.6 ccfl screen (although schematic mentions led)
                              From an inverter datasheet:
                              There are two control signals that come form syst
                              em to control lamp brightness. One signal is
                              named DAC_BRIG, which limits curr
                              ent to meet LCD lamp current specification. Another one is
                              named PWM, which adjusts lamp br
                              ightness. This invert
                              er brightness is adjusted by PWM burst
                              mode. The PWM burst mode is that turning on and
                              off the lamp at rate of 150Hz. The effective
                              brightness is a function of the duty cycle.
                              ENBKL signal is raised from Northbridge and goes to KBC
                              • ktmmotocross
                                Boardkiller
                                • Feb 2014
                                • 3553
                                • slovakia
                                but i dont have problem with backlight. i have problem with no lcd daa. i can turn on backlight but still no data or bad data
                                • ktmmotocross
                                  Boardkiller
                                  • Feb 2014
                                  • 3553
                                  • slovakia
                                  flashed bios, no change
                                  for me it looks like bad clock signal or something like that. the image is distorted but i see that is something displaying but its lines
                                  • atsio
                                    • Oct 2013
                                    • 819
                                    • Greece
                                    You have to remove Northbridge and check lines to lvds connector
                                    • ktmmotocross
                                      Boardkiller
                                      • Feb 2014
                                      • 3553
                                      • slovakia
                                      Ilast time i have sb off the board i checked these connections and it was al good.
                                      What is lcd clock frequency? Now dont have scope to chrck it.
                                      • atsio
                                        • Oct 2013
                                        • 819
                                        • Greece
                                        What is SB has to do with GMCH_TX*** lines?
                                        • mferna14
                                          Lenovo YOGA 910-13IKB cannot use External Display
                                          by mferna14
                                          Dear Friends., I am working on a Lenovo YOGA 910-13IKB. It is working fine, no problems at all. Today I was connecting to a External Display through the USB-C HUB, it could not connect. (This Lenovo model has only 2 USB-C Port, no HDMI, so has to be connected through a External USB-C HUB). I have changed the setting to External display but still no luck. Re-loaded Windows 11, assuming that the software might be faulty & still same. I know my USB-C port HUB is 100% good (HDMI, USBs, SD Reader) as I use this on all MacBooks & even my buddy has another HUB, still cannot connect to External...
                                          08-16-2023, 07:58 PM
                                        • ArchangelGabriel
                                          Aorus 17G YD laptop, broken display, could not switch to external monitor
                                          by ArchangelGabriel
                                          Hello guys! I need a little help, I have one laptop for repair, it is an Aorus 17G YD, gaming laptop. Broken display, some cable ripped form daughter board connector, case broken, battery discharged and probably locked, etc. After I did the most tedious job I ever did on soldering back the broken cables (shielded cable) , I measured resistance on CPU and GPU core, 3 and 5 v ps and any coils I find on the board, everything seems to be fine. After I plugged the charger I don't get the power led light on from the charger connection maybe because the battery is locked , but on power button I have
                                          11-23-2023, 03:55 AM
                                        • lawrenceptrini
                                          Lenovo Ideapad Flex 5 14ITL05 Only working on external display
                                          by lawrenceptrini
                                          Hi Guys,
                                          LENOVO IDEAPAD FLEX 5 - 14ITL05
                                          BIOS VERSION - FXCN24WW
                                          EC VERSION - FXEC18WW
                                          MTM - 82HT0004US
                                          SERIAL NUMBER - R9130MDP
                                          CPU - i7-1165G7
                                          This laptop powers on but shows nothing on the internal display.
                                          However, if I attach an external display it works fine.
                                          Observations: When I shut down the laptop from windows,
                                          the fan remains spinning until I close the lid. If I leave the lid open
                                          the laptop will restart on it's own although I select shut down from windows.
                                          Also, when I check the voltage on the...
                                          10-15-2024, 12:47 PM
                                        • AccountSaver
                                          Lenovo Thinkpad E15 Gen 2 NM-D011 - No display ? External , yes!
                                          by AccountSaver
                                          Here is a pretty crazy one.
                                          Step 1.
                                          Laptop was brought to me as dead not working. Removed everything , cleared everything.
                                          Step 2.
                                          Some liquid damage close to the Type - C connector, and the connector even though it was cleaned wasn't charging the battery . Removed the Type-C port, and replaced it. Now the laptop turns on and charges battery. Shows external screen , not internal.
                                          Step 3.
                                          Took out the screen and checked it to a secondary Gen 2 i have, screen works like a charm.
                                          Step 4.
                                          Lets ,dive into the board. I see the edp cable on the...
                                          05-07-2025, 07:16 AM
                                        • plyanthony
                                          Razer Blade 15 no external display with attached screen disconnected from motherboard
                                          by plyanthony
                                          Computer in question : Razer Blade 15 2020 Base Model
                                          Model# RZ09-03286E22
                                          BIOS CHIP: WINBOND W25Q128BV
                                          What I'm trying to accomplish:
                                          I want the computer to properly boot with an external display with the attached display disconnected from the motherboard. I have a CH341A programmer and full capability of modifying the BIOS easily. I Have tried various setting changes to no Avail.
                                          What I've tried thus far: Too much to note and I really dont remember everything I changed but here it goes.
                                          W/Stock BIOS - 1.06:
                                          Disconnect the...
                                          02-01-2023, 09:35 PM
