Dead A1278 (Early 2011) Macbook Pro?
  • d.ferch
    • Dec 2015
    • 11
    Re: Dead A1278 (Early 2011) Macbook Pro?
    Originally posted by rccrasher65
    Anyone have any 820-2936B version dead boards for parts for sale?
    hey i have 1 820-2936-b dead board. how much r u offering for the dead board? txt me if so
    Dan
    d.ferch@me.com
    (805)732-3996
    • angel-boy
      • 550
      • Romania
      #42
      i have a 820-2936-b board that not charging the battery and not available , i change ISL , nothing change. any help ?
      Q7085 , Q7080 i have voltage.
      • ciki
        • Aug 2014
        • 132
        • Ireland
        #43
        Can someone upload again schematic for this board or board view thx
        820-2936-B
        Have problem that when you turn on fan spin for 2 sec and off ,no post no, beep
        • haywater
          • Dec 2015
          • 3
          • united kingdom
          #44
          I'm new to this but I have a water damaged 820-2936-B which I have cleaned the board and mainly looking good. I have a couple of bad caps/resistors which could do with replacing but don't have a board view file for this model.
          Any chance someone could upload the file for me.
          Cheers
          Steve
          • dellxps15
            • Feb 2014
            • 1598
            • italy
            #45
            820-2936 boardview+schematics.
            • pateldee@live.co.uk
              • Jul 2014
              • 3
              Was there a resolve for this problem? I have a 820-2567-a (a1342 board) which is showing me low resistance as well, 7.4ohms, I have another 2 boards that shows around 34.0 ohms which work but have other issues. Removed two coils and caps after coil to cpu and still cant get 34 ohms, theres nothing else, surely the cpu is making this 7.4ohms?
              • Rav_tangle
                MacBook Pro 2011 turns on with keyboard light , screen dead
                by Rav_tangle
                Hi all , thanks for having me & I think this has been asked before but my case seems a bit odd.
                I have a MacBook Pro , board 820-2915a and it turns on , chimes etc etc , keyboard lights up, fans spins , can turn caps lock on/off but screen is dead.
                Iv tried the resets , shine torch through back logo , nothing , it seems the screen has no power. If I plug charger , it charges but if I disconnect battery it displays green light but won't turn on. Iv tried screen on with another board & it works & seems I'm not getting any voltage at pin 2 , next to ground pin .
                is this...
                05-31-2024, 04:09 PM
              • mrsith
                Macbook Pro early 2011 - no audio
                by mrsith
                Hi. Got a Macbook Pro early 2011 model, EMC2419, with no audio. Was hoping for a loose speaker cable or audio jack replacement...
                Upon opening I have discovered some liquid damage. The R6211 had obvious corrosion. Replaced it and cleaned the board PCB as much as I could. Still no audio (no output devices, no startup chime, and before Macbook shows apple logo with loading bar, it displays white screen for about 10 seconds). I have noticed solder joints around audio jack a little bit worn/bad, corrected them so they appear neat now.
                Anserwing some questions before they're asked:...
                06-28-2022, 03:32 AM
              • Rezendes
                Looking for 13" Macbook Pro A1278 mid 2012 820-2565-A Schematics and Board View
                by Rezendes
                Hello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
                I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
                The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...
                05-10-2024, 02:18 PM
              • pcbmaniac
                MacBook A1278 (3115) No PPBUS_G3H Issue
                by pcbmaniac
                Subject: Help Needed: MacBook A1278 (3115) No PPBUS_G3H Issue
                I'm working on a MacBook A1278 with the 3115 logic board and facing an issue with no PPBUS_G3H voltage. Here's what I've checked so far:
                1. U7000 Measurements:
                  • Pin 3 has 0V, even though R7012 shows 16.5V from PPDCIN_S5_CHGR.
                2. Resistors:
                  • I measured R7010 and R7011 with one leg disconnected, and both tested OK.
                Based on these findings, I believe U7000 needs to be replaced. However, I have a related question:
                • If I also decide to replace the SMC, do I need to order it pre-programmed,
                12-02-2024, 04:12 PM
              • jesi
                macbook pro a1707 dead
                by jesi
                hi all techs
                require some help on this 820-00281-A macbook motherboard came in dead and the pch bga U1100 (SR2NH), u5000 , Q7056 , U7000 and bios U6100 ,looks like these have been tampered with ..also the battery is swollen..
                adapter usb c 20.5v 4.7a 96w , i persume it should power on mb without battery..
                update:
                when adapter plugged in , power switch which 3.3v on it , when power button pressed both fans come on after 6 secs for about 20secs approx then goes off , nothing on the display stays as blank.. the voltage at the usbc out start from...
                08-24-2025, 04:34 AM
