Dell E6430s LCD replacement
  • tibimakai
    • Jan 2012
    • 3680
    I have this laptop, with a vertical line, which I'm trying to replace.
    I have found the same part number screen, which is for an HP laptop.
    This screen should work in the Dell, right?
  • WGenius
    • Apr 2015
    • 31
    • Algeria
    Re: Dell E6430s LCD replacement
    of course
    sigpic
    • tibimakai
      • Jan 2012
      • 3680
      I'm new here, at the laptop section. I'm over the TV section.
      There it works I know, just wanted to be sure, that on a laptop is the same rule applies.
      Thank you!
      • dj_ricoh
        • 2073
        Only dell and hp are SPECIALS.
        Only on lamps.
        On led all you need to know its resolution support.
        Somethimes you get artifacts on screen because the screen its full hd
        • tibimakai
          • Jan 2012
          • 3680
          This is the one I'm looking at.
          http://www.ebay.com/itm/HP-ProBook-6...:X:RTQ:US:1123
          If I search for the LG part number, it shows that this should be good.
          That HP, came with a higher resolution screen as well(1600x900), but I assume that has a different part number.
          It's an LED screen.
          • tibimakai
            • Jan 2012
            • 3680
            OK, the screen works.
            Anybody has a schematic for this laptop?
            I'm trying to add a webcam. I have purchased one and the bezel for it.
            Windows installed the driver for it(it shows that is working), but it still does not work.
            I'm thinking, that maybe it's not getting the USB voltage. It used to be, only a mic array up there before.
            There is only a video cable and there is no USB connector going to the motherboard.
            • dj_ricoh
              • 2073
              The webcam cable its with the video cable.
              Test the webcam with vlc .
              • tibimakai
                • Jan 2012
                • 3680
                Does not work with it.
                It seems like the player works(no error messages), just does not show any video on the screen.
                • reformatt
                  by reformatt
                  07-31-2025, 08:37 PM
                • angel35
                  Dell E6430S No screen help request
                  by angel35
                  I receive an wrong Dell E6430S, Not start no have screen.
                  Spec:
                  S mean Slim, not normal "fat" E6430, CPU soldered BGA CPU: i5-3340M SR0XB
                  Motherboard: Compal LA-7741P QAL70 r1.0 A00
                  Symptom:
                  Not start no have screen, no have backlight (full black), but board is working, Status LEDs ok, CPU start to hot and Fan spin up. Northbrigs also hot.
                  Main Battery charging, and can run form battery (run means you can turn off, CPU is hot, fan works)
                  Looks like everthings ok, but not work
                  I changed Memory, plug out SSD,(SSD...
                  11-24-2024, 12:12 PM
                • VcemPzd
                  Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                  by VcemPzd
                  Hello everyone !
                  My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                  04-28-2025, 10:14 AM
                • jean luc ferre
                  laptop hp g72 b52sf screen problems
                  by jean luc ferre
                  on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                  the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                  i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                  i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                  06-07-2025, 03:27 PM
                • FreakyMex
                  Trouble to identify part (Lunii screen) for replacement
                  by FreakyMex
                  Hello guys. I'm a complete noob in electronics. I'd like to repair my child Lunii's (a "story box"), basically an audio player that allows the childs to choose between several options the places, characters, objects of the story, and then play a story according to the choice of the child. There is a screen that display the selected option before each choice. The Lunii fell and the screen is now broken.
                  I'd like to repair it (probably just have to change the part, because the lunii still works perfectly fine) but I can't manage to identify the part/order it online. Do you have any...
                  02-17-2025, 01:16 AM
