HP 4510s power problem
  • Dr.Spiegel
    • Apr 2015
    • Praga
    Hello guys, i see lots of you got really lots of knowledge, so i hope somebody can help me with my notebook.The problem is that i try to switch it on, but after pushing the power button, it stayed absolutely dead, also LED indication in DC conector is not working. I am not clever from this situation but i got schematics and i also wanted to ask you, if u know about some issues of this laptop.
    What i already done:
    1) Tested power supply adapter - works fine, its oK
    2)Measured voltage going from the power supply to mainboard-its ok
    3)Change the LM339 on mainboard, still the same issue
    I am including schematics in this post so please take somebody a look and tell me where the problem can be (FDMC4435, LM393...). Please help
  • aanan
    • Dec 2010
    • 222
    • India
    Re: HP 4510s power problem
    check 1st +V5AL on u1021 pin no5 schematic page no5 2nd check page no7 +V3A & +V5A.
    • dj_ricoh
      • 2073
      • uk
      Even with bad bios the light from dc connector wont come on.
      I suggest to start with that.
      Reflash bios chip.
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3577
        • slovakia
        as first even bios need 3.3V ALW power, so i will start from that
        • smali
          • Sep 2014
          • 287
          • Pakistan
          my suggestion is first check the voltage main voltage line on Q1031 source or R1262.
          have you received adopter 19 v on that points?
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            Reflash bios chip.
            Yes, that is correct. But like others said above, check the 3.3v ALW rail first. You can check that on pin 8 of the BIOS chip.
            A working TV? How boring!
            • Dr.Spiegel
              • Apr 2015
              • Praga
              Oh wow! Thanks a lot! I hope tomorrow or in Sunday i will measure every value. Anyway i will report progress!
              ktmmotocross: ZdravĂ­m na Slovensko.
              • theone111
                by theone111
                3. Problem: TV shuts down
                07-22-2024, 10:36 AM
              • Duranitron
                Asus x512dk rev 2.1 power on problem
                by Duranitron
                When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
                Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
                11-26-2024, 10:22 PM
              • EazyBone
                LG OLED55C9PUA power problem
                by EazyBone
                Hello, trying to fix C9 55 inch. I have pulled the back and all looks completely normal with nothing burnt so far. This is first time attempting to fix a tv so any help is appreciated.
                Problem. I hit power button, red light on TV turns off and tries to turn on, no picture shows up and then shuts off. This occurred after house power turned on and off, not from a storm.
                I have tested the power going from power supply to main board, all 12v and 20 volt readings are proper when I hit power button.
                The power supply to t con is different story.
                This...
                06-23-2023, 07:43 AM
              • Dr.d
                Help please..Lenovo ideapad 5 14itl05 power and charging problem
                by Dr.d
                I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
                Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
                04-05-2024, 11:48 AM
                03-31-2024, 02:12 PM
