Hello there, so today I think I broke a laptop, I have DELL L502X with I7 and it had faulty HDD and USB 3.0 connections, so I replaced connection, insert new HDD and now whenever it gets power the fan start spinning at full speed, but no video, no reaction to power button, what could have I broke Southbridge? Northbridge? It doesn't matter even if i take out cpu and RAM it still starts spinning, tried changin different CPU, RAM, but no luck :/
Dell l502x
Re: Dell l502x
http://www.4shared.com/file/07bIixPF...502X_bios.html bios dump , I won't use it in futureNo shorts found, already changed Southbridge, as the northbridge is in nVidia...
Re: Dell l502x
did cpu and gpu get hot ?
voltage on cpu and gpu after power on ?Comment
Re: Dell l502x
KBC replacement helped! As the USB ports where repaired I think there could be the problem... http://s18.postimg.org/v74tpybqx/111...91965195_n.jpg At the component LI 3 and 4 has short and 1 is shorted to 2, 1 to 3 has 996ohm and 2 to 4 1185ohmComment
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by master3112I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...-
Channel: Schematic Requests ONLY!
by sahamipoorhello...
the Dell XPS L502x ( Model P11F ) [ DAGM6CMB8D0 rev.D ..3 of lines output LVDS from PCH has short ohm(0 -70) than LCD displat turn ON but is white !!!
i decide to change LVDS ports to Lcd from EXT_LCD graphic Studio Discrete to No need it LVDS lines of PCH use...
according to ُSchematic ,I changed any resistor and... Config_0 and Config_1 EC...but:
1- EXT_LCD_PWM no voltage to enable pwm
2-EXT_LVDS_VDDEN no High to Enable LCD_vcc
and screen is turn off and fan is high Speed!!
Question:
I need to Use Discrete graphic nvidia EXT_LCD ports... -
by diamonI have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
Pictures of these boards:
Dell Latitude 5520 https://www.ebay.com/itm/256052956663
Dell Latitude 5530 https://www.ebay.com/itm/125844181534
Dell...4 Photos -
by lalle-Hello!
I have a problem with a Dell G5 SE 5505 laptop that I hope someone can give me a few pointers on.
[OK, it's not really a laptop, I'm running the motherboard on my desktop with only cooling, RAM and an M2 drive attached.]
I had some performance issues, so I decided to update my BIOS from 1.7.0 to the latest version, 1.20.0.
The computer restarted and the update dit not want to continue without a battery connected, even though I used dell's method of bypassing this requirement.
I tried updating to a custom BIOS from Reddit user Satori_Nori https://www... - Loading...
