HP 8460p won't wake up after sleep, needs hard reset and restart
  • withalligators
    • Jun 2013
    • 267
    Hey folks,
    Fresh install of Windows 7 Ultimate 64 on an Elitebook 8460p. This model has an i5 vPro 2520 with an AMD 6470M GPU. I put a 240GB SSD in there, and decided to do a fresh and clean OS install. After the full install, with all of the drivers and firmware of the HP support site as well as a BIOS update, I have a really annoying problem.
    Whenever the laptop goes to sleep, and I subsequently try to wake it up, it only partially wakes up. The power LED illuminates and the fan kicks on as if it were on. The wifi indicator LEDs also come on but only in orange, as does the mute button. The HDD access LED kicks on for a second when you first try and wake it, but then shuts off.
    This issue is really annoying, and I've researched a ton how to fix it, but to no avail. I've read that tons of HP laptops with AMD cards have this issue, but none of the solutions people had seem to apply to me. Many mention an issue with the switchable graphics and using older Intel drivers, but the 8460p doesn't have a switchable graphics option in the BIOS or in catalyst converter. Also, I can't seem to install ANY intel graphics drivers for this CPU or the HD 3000 so I'm assuming it's locked out by the AMD card.
    Any help?
    Thanks,
    Alex
  • withalligators
    • Jun 2013
    • 267
    Re: HP 8460p won't wake up after sleep, needs hard reset and restart
    Ok, well, after updating the BIOS, which didn't fix it, I restored the BIOS defaults, which did. Computer now works fine. I wonder what setting that worked with my previous install doesn't work with my new one.
    • sunilnjarakkat
      • Dec 2013
      • 13
      • u.a.e
      Change i/o chip
      • withalligators
        • Jun 2013
        • 267
        • dj_ricoh
          • 2073
          change the battery bios .
          maybe it forgets how to wake up
          • withalligators
            • Jun 2013
            • 267
            Guys, I really appreciate you chiming in, seriously, I do. But if you look at my second post, I fixed it. I reset the BIOS to default settings now everything is fine. It's weird that it worked with those settings on my previous install, but not with my new install. Whatever, it's working now. Thanks though!
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              twas the bios update not reading CMOS the same way as before. the update should fix the bits in CMOS, but not always. like if you jump 4 versions it may not. that's what ive found anyway with the thousands of computers i've refurbed, BIOS update being a standard process of the refurb.
              Follow the white rabbit.
              • withalligators
                • Jun 2013
                • 267
                I would agree, but the problem existed preBIOS update. I flashed the BIOS to try and fix the problem.
                • goontron
                  5000!
                  • Dec 2011
                  • 4108
                  • US
                  CMOS corruption is also common, though, i see it mainly with Dells dimension line and crappy gateways.
                  • withalligators
                    • Jun 2013
                    • 267
                    Never had the pleasure of coming across it. I will say this though, while most laptops and PCs are fine with a quick reinstall of windows, and maybe a few drivers off the manufacturer site, HPs are always the biggest pain to get running. They hate fresh installs. There is always a problem of some kind.
                    • hamzkt
                      • Feb 2013
                      • 4
                      • saudi arabia
                      anyone have shematic HP 8460p mb 6050a2398501-mb-a02
                      the mo therboard burn near lvdo connector , system working but no backlight
                      • zeg12345
                        A2141 820-01700-A MacBook Pro (16-inch, 2019) 2.3GHz i9 32GB RAM 1.0TB SSD - Unable to wake from extended sleep
                        by zeg12345
                        If the lid is closed or the system is put into sleep mode for more than 30 minutes or so, then when I try to wake it back up by tapping a key or by tapping the power button I get no response. The device is warm but the CAPS lock light on the keyboard is unresponsive. To get it to reboot and be functional again I have to hold down the power button to force it to power off, then when I press the power button it reboots normally. I erased the system and reinstalled macOS to do a factory reset, and the issue still persists. I replaced the logic board and the issue is resolved with a separate known...
                        03-15-2024, 12:06 PM
                      • kingskie
                        820-01987 no backlight when wake up from sleep
                        by kingskie
                        I have a problem with 820-01987 that has no backlight when wake up from sleep. before there was water damage around U6903 and backlight caps. no corrosion found so i just clean it up. is there any component that in charge for enable backlight after wake up from sleep mode?
                        any suggestion would be appreciated.
                        08-05-2022, 02:51 AM
                      • colos85
                        A1286 with 820-3330 sleep wake failure in efi, battery drains fast
                        by colos85
                        Let me share you a story that could be useful - not just with this model mentioned.
                        Symptoms:
                        - Battery drains fast, 20-25% a day while sleeping.
                        - As soon as it runs flat Mac turns off, like normal.
                        - When hooked on charger starts twice (two chimes), then boots normally, but a message appears in the OS "Sleep wake failure in EFI..." The exact message already lost, but many things can cause this as I saw, so wont point out the source of the problem.
                        So I changed in pmset the standbydelays to 100, and hibernatemode...
                        10-08-2020, 10:57 AM
                      • sugarfoot
                        Asus PA279Q wake from sleep and power issue
                        by sugarfoot
                        Hi, my display no longer wakes from sleep. Half the time it won't power on at all. It also occasionally flashes black, white, red, blue, green and says "press menu and shortcut 2 to disable burn in".
                        It's a great monitor, I hate to give it up without a fight.
                        Are there any service manuals for this display? How do I disassemble it and see if there are any blown caps? Thanks.
                        10-13-2023, 11:03 PM
                      • shouri
                        Dell latitude e5490 auto restart
                        by shouri
                        Hi guys, can someone help me?
                        I have an issue with laptop dell latitude e5490 that auto restart when arrive at certain point in loading windows.
                        Board model is dm70 la-f401p rev:1.0 2017-09-20.
                        At first, the issue is sometime ssd sata 2.5 not detected. i already try another cable, at certain point, it ok using old cable (i mean sata cable here).
                        After a few days test, is seems ok.
                        Days later, another issue come, that is auto restart when certain point in loading windows. i already test another ssd, another ram, another sata ribbon, still same....
                        12-10-2024, 09:27 PM
