Asus PA279Q wake from sleep and power issue
  • sugarfoot
    • Oct 2023
    Hi, my display no longer wakes from sleep. Half the time it won't power on at all. It also occasionally flashes black, white, red, blue, green and says "press menu and shortcut 2 to disable burn in".
    It's a great monitor, I hate to give it up without a fight.
    Are there any service manuals for this display? How do I disassemble it and see if there are any blown caps? Thanks.
  • GLISIT
    by GLISIT
    01-16-2025, 02:29 PM
  • bajdik
    Intermittent Power Issue on Asus X553MA – CPU Voltage Drops ftom 0.89V to 0V
    by bajdik
    I have a problem with an Asus X553MA motherboard. Sometimes the system works fine, but other times the CPU voltage drops to 0V. In most cases, the laptop reboots after a few seconds due to the voltage drop.
    Occasionally, it shows the ASUS logo or boots into the BIOS. Sometimes it can stay in the BIOS for hours without issue.
    I checked the board with a thermal camera, but I couldn't find any overheating or leaking capacitors.
    Unfortunately, I don’t have access to the schematic.
    It seems to me that when I bend the board, something changes.
    Could this...
    08-13-2025, 07:26 AM
  • garretofriviaaaaa
    Asus TUF Dash FX516PM Power Issue
    by garretofriviaaaaa
    Hello, I've had a problem with this laptop for a while. I've replaced the motherboard after it died, and it was seemingly working fine after, but it stopped powering on after I shut it down. if I remove the battery connector and plug it back in, it will boot fine, but if I shut it down again it will not power up after that until I unplug and replug the battery in. When I press the power button the caps lock light will light for half a second but will not boot. I've tried replacing the RAM and the battery but still the same issue. The only thing I've found to get it to turn on consistently was...
    08-29-2025, 05:47 PM
  • MakNCheese
    ASUS Zephyrus GA401I Severe Lag, Suspect Motherboard/Power Issue - Need Help Diagnosing
    by MakNCheese
    I'm having a serious issue with my ASUS Zephyrus GA401I (4 years old, worked perfectly until recently). The system is lagging heavily, even in the BIOS, and is charging extremely slowly (a few percent in hours), making it nearly unusable. I suspect a motherboard or power delivery issue.
    Symptoms:
    • Severe lag across the system, including BIOS navigation.
    • Slow boot times and unresponsive performance in Windows.
    • Battery charges very slowly (e.g., ~5% in 2–3 hours).
    • No error messages or BSODs, just extreme sluggishness.
    What I've Tried:
    • Replaced
    06-04-2025, 12:48 AM
  • conghuyms
    Asus fx516pc Gaming issue No Power GPU. pls help me !
    by conghuyms
    Hello everyone, I’m working on the motherboard of an ASUS FX516PC. Initially, the laptop had no response at all because the user replaced the RAM and accidentally caused a short circuit, which burned the EC. I replaced the EC and the machine now powers on and shows display, but it does not detect the GPU.
    When I check the GPU power rails, there is no voltage for the VRAM and no 0.9V for the Vcore. The DGPU_FBVDDQ_EN signal, which enables the VRAM power, is missing. At the LOGIC IC SLG4U44336V (STQFN20 package), I have +3VSUS and 1.8V MAINEN_GPU. I replaced the SLG4U44336V logic...
    11-30-2025, 05:25 AM
