820-01987 no backlight when wake up from sleep
  • kingskie
    • Oct 2014
    • 249
    • indonesia
    I have a problem with 820-01987 that has no backlight when wake up from sleep. before there was water damage around U6903 and backlight caps. no corrosion found so i just clean it up. is there any component that in charge for enable backlight after wake up from sleep mode?
    any suggestion would be appreciated.
  • kingskie
    • Oct 2014
    • 249
    • indonesia
    Re: 820-01987 no backlight when wake up from sleep
    when no backlight after wake up from sleep mode, i turn off the macbook with power button and then try to power on with power button again. and still no backlight.
    but if i disconnect the battery and reconnect and turn on the macbook, the backlight is on. but backlight off again when wake up from sleep mode. already tried PRAM reset bust still the same.
    • mon2
      • 14333
      Check if the lid switch is working which is a logic level used to tell the logic board the lid is open or closed.
      Believe that is a hall effect (magnetic) sensor linked to the track pad. Check to see if your track pad cable is clean and with proper contact.
      The backlight ic will have an enable pin. When it works, check the enable pin value. When backlight is off, check again.
      • kingskie
        • Oct 2014
        • 249
        • indonesia
        hi @mon2,
        update:
        now the backlight is fully off even after dissconnect the battery. what should i check first?
        • mon2
          • 14333
          Same points of interest. The backlight input voltage that is used to boost to create the backlight.
          What is the voltage before the backlight IC?
          Enable logic pin on the backlight IC - voltage?
          The actual backlight voltage value?
          Does the caps key led toggle? To confirm logic board is booting.
          Also, this model is impacted by the Flex gate fault where the video cables are too short and get broken over time.
          https://boards.rossmanngroup.com/thr...ning-on.61731/
          • kingskie
            • Oct 2014
            • 249
            • indonesia
            hi @mon2,
            these are my measurements:
            PPBUS_G3H = 12.58V
            PPVIN_S0SW_LCDBKLT_R = 12.58V
            BKLT_SD = 0V
            LCDBKLT_EN_L = 0V
            the value for R8402 and R8401 is normal.
            the caps key led is on, and i can see image but no backlight
            this is 2020 model, does it have problem with flex gate? i already check the flex gate all looks good.
            can i use 2016-2018 screen to test with this model?
            • kingskie
              • Oct 2014
              • 249
              • indonesia
              update:
              i change Q8400 and the problem solved.
              thanks for the help @mon2
              • triplefour
                by triplefour
                09-13-2023, 10:43 PM
              • luckydip
                820-00840 no backlight after sleep
                by luckydip
                Came in dead, the backlight area and both rows of backlight caps were misaligned and fluxed.Got it working but has a sleep/backlight issue. When you close the lid, display darkens but when you open the lid the backlight doesn't restart - dim display as if no backlight. No other obvious liquid damage.
                If you put it to sleep via the Apple menu then it wakes up fine with backlight.
                Things I've tried - replaced hall sensor, replaced U5255 and given the SMC a light reflow - still no change. U5255 area resitors all ok. Any other ideas?
                thanks...
                09-03-2021, 05:53 AM
              • saidbe
                HP 850 G3 unable to wake the computer from sleep or standby mode
                by saidbe
                HP 850 G3 i get black screen and unable to wake the computer from sleep or standby mode. I have to hard restart the laptop. Any idea?
                07-03-2024, 06:25 AM
              • zeg12345
                A2141 820-01700-A MacBook Pro (16-inch, 2019) 2.3GHz i9 32GB RAM 1.0TB SSD - Unable to wake from extended sleep
                by zeg12345
                If the lid is closed or the system is put into sleep mode for more than 30 minutes or so, then when I try to wake it back up by tapping a key or by tapping the power button I get no response. The device is warm but the CAPS lock light on the keyboard is unresponsive. To get it to reboot and be functional again I have to hold down the power button to force it to power off, then when I press the power button it reboots normally. I erased the system and reinstalled macOS to do a factory reset, and the issue still persists. I replaced the logic board and the issue is resolved with a separate known...
                03-15-2024, 12:06 PM
              • DanPoka
                by DanPoka
                02-15-2025, 05:05 AM
