HP G6-2210sa No power
  • claudyu07
    Claudyu07
    • May 2014
    • 125
    • Ireland
    Hi guys . i have a HP G6-2210SA with no power .
    I don't have schematics if anyone can share them.
    Thank you!
  • meritosari
    • Oct 2010
    • 774
    • Indonesia
    Re: HP G6-2210sa No power
    schematic:
    • claudyu07
      Claudyu07
      • May 2014
      • 125
      • Ireland
      thanks
      • claudyu07
        Claudyu07
        • May 2014
        • 125
        • Ireland
        If someone can help to troubleshot the problem will be greatly appreciated.
        • claudyu07
          Claudyu07
          • May 2014
          • 125
          • Ireland
          anyone?
          • dellxps15
            • Feb 2014
            • 1598
            • italy
            do you have light on power supply connector on pc ?
            • claudyu07
              Claudyu07
              • May 2014
              • 125
              • Ireland
              no. no lights at all
              • cyberhack
                • Feb 2013
                • 466
                • Uk
                Have you replaced the dc jack if so did you check the it was wired correct as I have done one and they sent the dc jack wired wrong
                • Mario
                  • Sep 2007
                  • 64
                  Did you try with another charger? I seen the center pin broke or disconnect. Charger will test ok but won't do anything because the charger id pin is missing.
                  • claudyu07
                    Claudyu07
                    • May 2014
                    • 125
                    • Ireland
                    charger is grand . i have on DC-IN connector (CN16) pins:
                    1 & 2(VDD) - 19v
                    5(AD_ID) - 0.65v
                    7(power led) - 0.04V
                    • cyberhack
                      • Feb 2013
                      • 466
                      • Uk
                      PQ50 voltage?
                      • claudyu07
                        Claudyu07
                        • May 2014
                        • 125
                        • Ireland
                        Originally posted by cyberhack
                        PQ50 voltage?
                        Pin 1- 24V
                        Pin 2,3,4 - 19V
                        • cyberhack
                          • Feb 2013
                          • 466
                          • Uk
                          3v and 5v : pu8
                          oh does it work on battery
                          • claudyu07
                            Claudyu07
                            • May 2014
                            • 125
                            • Ireland
                            no. but i don't know if battery is charged or not .
                            When i plug in the AC adapter and quick press the power button lights come on for fraction and goes off.
                            • cyberhack
                              • Feb 2013
                              • 466
                              • Uk
                              I would recheck the charger
                              • dellxps15
                                • Feb 2014
                                • 1598
                                • italy
                                if no light on psu charger notebook case, try ec bios.
                                • claudyu07
                                  Claudyu07
                                  • May 2014
                                  • 125
                                  • Ireland
                                  PU8 3.3ok , 5v ok , 19v input ok.
                                  @cyberhack is universal charger that i just used now with 3 different laptops and it's working.
                                  @dellxps15 i have an EPZ2010 bios programmer . don't think the bios on this board is compatible with my programmer.
                                  UPDATE.
                                  When pluged in, power button flashes every 5 seconds
                                  • cyberhack
                                    • Feb 2013
                                    • 466
                                    • Uk
                                    I have had 3 chargers that did not work on this model
                                    had to get the correct 1
                                    • claudyu07
                                      Claudyu07
                                      • May 2014
                                      • 125
                                      • Ireland
                                      hmm. i am wondering now how to find correct one.
                                      • dj_ricoh
                                        • 2073
                                        did you try to power the board outside the case?
                                        like put the board on the table take the power button out from palm rest , connect the dc cable and power it up on external.
                                        last week did a flash on hp and forgot to put the sticker on top the bios and it did the same power of half a sec the off.
                                        the board was on short because of that sticker missing
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          09-06-2024, 05:59 AM
