acer 4736z no power
  • rickybucalan
    • May 2013
    • 322
    • philippines
    acer 4736z no power
    hi guys. any one who experience this problem i got acer 4736z it has power indicator but when you press power on it goes off.
    i did replaced nectokin it just do the same problem.
    could it be bios problem? any who have bios dump for this model?
    tnx in advance...
  • Ramee
    • Jul 2014
    • 218
    • Israel
    Re: acer 4736z no power
    here
    • dj_ricoh
      • 2073
      • uk
      tnx in advance...
      chipset!
      i had a 6920 with crack screen just to test mxm video cards and i left it in the basement. apparently there was moisture there now when i press power it goes off after 2 sec.
      • rickybucalan
        • May 2013
        • 322
        • philippines
        Originally posted by dj_ricoh
        chipset!
        did u fix it? what did u do?
        • rickybucalan
          • May 2013
          • 322
          • philippines
          Originally posted by Ramee
          here
          tnx ramee i appreciate.
          • rickybucalan
            • May 2013
            • 322
            • philippines
            no luck it still no power
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3578
              • slovakia
              tnx in advance...
              check for short to ground on all big and small coils.
              • fddizon
                • Sep 2011
                • 555
                • Philippines
                ktm is right. check coils that is shorted to ground. (determining which section is causing the issue)
                post schematic and we will start fixing your mobo kabayan.
                • rickybucalan
                  • May 2013
                  • 322
                  • philippines
                  Tnx guys but i give up easily. i found one shorted coil and more tantalum caps behind gpu chip. I've tried to removed all of them but still shorted pad. so i assume that it couldn't fix it anymore cos it like liquid spill on it when i first saw the board.
                  thank you guys...
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3578
                    • slovakia
                    i think someboddy try to "reflow" chip and fry it, gpu chips ddont fry itself. if u have station u can replace it.
