Lenovo N500 wifi problem
  • mesersmith
    • Dec 2014
    • 35
    • România
    I have a Lenovo N500 and I have a weird problem with wifi card.
    So, when is booting, I receive a message that tells me that wifi card is not recognized and the sistem is halt.
    I tried several wifi cards, but no success.
    The original wifi card was 5100 from Intel, but it was phisically broken.
    I put another 5100, but I have same message.
    This laptop I presume that is reading from wifi card, since it gives me this message.
    I put newer bios, but no success.
    Is there someone who have this problem?
  • khaahk
    • Dec 2013
    • 760
    • Estonia
    Re: Lenovo N500 wifi problem
    Some branded machines are using so called "whitelist" of devices which can work on the laptop. You have to find specific card for that model by Lenova partnr or hack the bios. Search internet for that matter.
    • TVRepairNoobie
      • Feb 2015
      • 158
      mesersmith, Have you tried to remove the Wireless card all together to see if you can boot?
      Other Option: Change Boot order in BIOS, First Boot Device = Hard Drive
      • mesersmith
        • Dec 2014
        • 35
        • România
        Yea, If I remove wifi card, the laptop works great, boot up in Windows and works like a charm.
        With wifi card inserted, the entire system is in halt state, it show me a message that says that the card is not verified and isn't right for this computer.
        The boot order is hdd first.
        • dj_ricoh
          • 2073
          • uk
          so what`s wrong?
          hp and lenovo got a list with wifi cards that ONLY work.
          last year i had half a kilo of wifi from spare notebooks.
          they all ended up replacing old cards
          • mesersmith
            • Dec 2014
            • 35
            • România
            Now I read about this whitelist.
            This laptop is one of many laptops that I bought en-gros, and I repair it and prepare it to sell.
            In this laptop, it was an Intel wifi card wich was phisically broken. I mean, it was cut in half.
            Without knowing about this whitelist, I tried 30 or 40 wifi cards and no one was the type that is included in that whitelist.
            Now I have to find one wifi card wich is appropiate to this Lenovo notebook.
            Thanks for all your answers.
            • dj_ricoh
              • 2073
              • uk
              good job!
              i rly hate this when it happens to me to yaaaaaaak
              • danro
                wifi whitelist Lenovo M920x
                by danro
                Please remove wifi whitelist from this Lenovo bios.
                If try to use another wifi card, unit no boot
                Original card: Intel8265NGV
                ThinkCentre M920x
                Model: 10S0S0GX00
                SN: PC12PQSF
                Here is the original dumps
                Thanks....
                07-17-2025, 03:48 PM
              • s_specialist
                Lenovo E15 Gen 2 GE4B0 GE5B0 NM-D011 Rev 1.0 sometimes not opening problem
                by s_specialist
                Recently, I have started to encounter a problem with Lenovo E15 Gen 2 models not opening. When you try to open the device, it gives a warning sound and does not display an image, when you apply light pressure on the keyboard, the image appears and works for a while, when you turn it off and on, the same thing happens again. Bios was tried, RAM slots were cleaned and soldered to the legs, the problem still persists. There seems to be a problem with the onboard processors, but since Lenovos glue the processor firmly from the sides, the paths are very damaged when removing it. Has anyone encountered...
                07-07-2025, 11:47 AM
              • perzyk23
                Lenovo T580 - LCD Panel problem - error 0288
                by perzyk23
                Good morning,
                I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                10-25-2024, 12:42 AM
              • konradx
                Lenovo Thinkpad T15 Touchscreen problem bios
                by konradx
                i have problem witch Lenovo T15, my LCD display was demaged, i buyed New LCD, Touch screen version. Problem is LCD Working but Touchcreen not working, i wrinted to seller . He sended to me another LCD, but still not working. I have to Lenovo T480s with touchcreen LCD and that display and touch work. I think that is somethink like whitelist support LCD in BIOS. Someone have the same problem?
                That is my DUMP.
                My device:
                SN: PF29Y4N6
                1s20S7S2WF00PF29Y4N6
                MB: GT4A0 GT5A1 GP4A0 GP5A1 GT4A2 NM-C931 REV 1.0...
                09-06-2024, 01:33 AM
              • madrali
                lenovo e15 gen2 bios ? problem
                by madrali
                Model: Lenovo ThinkPad E15 Gen 2 (Intel)
                20TD-50S0KU00
                Hi, my laptop suddenly shut down while it was running. When I try to turn it back on, the screen stays black and it emits a melodic beep.
                I used Lenovo's SmartBeep decoder and it returned error 0284:
                "TCG-compliant functionality-related error (possibly BIOS code validation failure)"
                I then tried to enter crisis BIOS recovery mode by pressing Fn + R at boot. The melodic error code changes, but nothing else happens regardless of whether a USB is inserted. I receive another...
                06-16-2025, 12:06 PM
