while pluged in it shows only green light and the laptop cant start but it on for a while then turns off and repate this.but if i pluged in a charge battery it starts fine and runs ok but still cant charge battery.i have change with new battery and charger alsoo but still same.i have also change charging ic near battery connector but still same.any ideas
					macbook pro A1728 cant charge battery
Re: macbook pro A1728 cant charge battery
Dear with me MacBook Pro A1502 EMC:2835 820-4924-A, problem give me x mark on battery, i replaced isl6259AHRTZ, R7120 0.02ohm, on one point gives me 15.94 and othere on 15.98 volt on battery jack 123pin 11.5 from battery and 4,5, 3.4v and pin 6 0.026 up and down... pls. help me out ........Comment
did anybody face this problem before......i also changed charging ic isl6259 three times but still same......with charger it wont turns on but keep on restarting but with a charged battery it turns on runs fine but shows not charging and charger light remains green....i changed magasafe also used ogignal also changed battery also but still same thingComment
Seems like something is trying to turn on and when that 12 volt device is not turned on or recognized as being turned on it then recycles. So there is a program loop that it is stuck in for what ever reason. If this was the intent of the programmer or the program is at fault.Comment
			by razenxdHello,
it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
Now, I have noticed a few things.
The "dead" battery, while connected to charger and NOT Charging will...-
			by ruleteroHi
Acer A515-43
LA-H801P
Fail: Does not charge battery, has low voltaje on connector.
Laptop didn't want to turn on, only charge led blinked.
I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know... -
			by ACS-RepairHello All,
I have a unusual problem with a MacBook Air 2014 820-3437 that it will not charge the battery. I have 2 batteries that charge just fine in another 820-3437 so i assume that the batteries themselves are OK. One was new in 2020.
This board started off as a PP3v3_S5 short that was resolved (shorted capacitor) and came to life fine. While testing the computer I noticed that the battery was not charging so I checked the following components:
Current sensing:
R7121 10 ohm
R7122 10 ohm
R7151 2.2 ohm
R7152 0 ohm
			Hello, I have a MacBook Air M1 that got water on it and now the computer does not charge the battery. The USB C port does work since I can connect the computer to HDMI for example. The battery also works well since if I connect a motherboard from another MacBook Air M1, the battery charges.
Anyone know what can it be?06-18-2024, 11:28 AM - Loading...
