Lenovo G480(LG4858L 11326) Power problem
  • YourLocalGeek
    • Feb 2015
    • 43
    • Philippines
    hi guys
    lenovo g480
    MB CODE: LG4858L MB 11326-1
    laptop turns on (automatically) only if cmos battery has been reseated.
    after shutdown, laptop does NOT turn on using power switch
    cmos battery has to be reseated again for it to turn on.
    any ideas?
    thanks in advance
    attached are the schematics
    please help
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Re: Lenovo G480(LG4858L 11326) Power problem
    check if u can start the board without attached power switch board. looks like your power button is not working
    • YourLocalGeek
      • Feb 2015
      • 43
      • Philippines
      thanks for the reply ktm
      but sorry board still wont turn on without power switch i tried switching it on by shorting pin 2(kbc_pwrbtn) to ground of btncn1 (power switch board port) or am i doing it wrong?
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3627
        • slovakia
        try to short KBC_PWRBTN_EC# on C2717 and check voltage on it
        • YourLocalGeek
          • Feb 2015
          • 43
          • Philippines
          same results boss still wont turn on
          voltage on c2717 is 1.11v
          is the kbc faulty?
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3627
            • slovakia
            check both sides of R2703 and R2704 for voltage
            • YourLocalGeek
              • Feb 2015
              • 43
              • Philippines
              R2703 1.11V both sides
              R2704 1.11v & 3.3v other side
              is that good?
              again thanks for the time ktm
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3627
                • slovakia
                1.1V is low. it must be 3V. check resistance of R2774 and R2704
                when nothing try to remove EL8204.
                all this things do with powerswitch board removed
                • YourLocalGeek
                  • Feb 2015
                  • 43
                  • Philippines
                  in circuit resistance
                  R2704: 9k
                  R2774: 13k
                  and then i removed el8204
                  same resistance but voltage changed from 1.1v to 3v
                  tested it out of circuit
                  r2704: 10k
                  r2774: 99.6k
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3627
                    • slovakia
                    ok,, u have 3V. so now try to start it by shorting KBC_PWRBTN_EC# on C2717 to ground
                    • YourLocalGeek
                      • Feb 2015
                      • 43
                      • Philippines
                      tried shorting c2717 to ground
                      mboard turned on for 1 sec then turns off?
                      it looks like i can switch it on now but now it turns off after 1 sec
                      tried it without cmos battery and i turned it off (after it automatically turned on) and tried switching it on again, it turns on and off after 1 sec
                      but for the 5th time mboard stays on
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3627
                        • slovakia
                        ok. so leave removed that coil and try to switch on with powerswitch board.
                        for that 1s switching check power sequence at the end of schematic
                        • YourLocalGeek
                          • Feb 2015
                          • 43
                          • Philippines
                          thank you ktmmotocross for your time and guidance
                          laptop works great now
                          for the 1s switching, i just assembled the laptop (i think its because there was no cpu before) and it worked with just 1 press to turn it on.
                          thanks again boss
                          more power to badcaps and to ktmmotocross
                          • mcoytzhi27
                            Mr
                            • Nov 2015
                            • 43
                            • philippines
                            any dump files for this unit.. thanks...
                            • andrew25
                              • Feb 2016
                              • 224
                              • Malawi
                              need bios dump too for it
                              • andrew25
                                • Feb 2016
                                • 224
                                • Malawi
                                • Homero
                                  • May 2018
                                  • Pery
                                  Originally posted by YourLocalGeek
                                  hi guys
                                  lenovo g480
                                  any ideas?
                                  thanks in advance
                                  please help
                                  try reprogramming the BIOS. I leave the link here:
                                  https://mega.nz/#!2R9CnSLL!PJJugfreu...tgyi83gBmvNds0
                                  • Dr.d
                                    Help please..Lenovo ideapad 5 14itl05 power and charging problem
                                    by Dr.d
                                    I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
                                    Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
                                    04-05-2024, 11:48 AM
                                  • theone111
                                    by theone111
                                    3. Problem: TV shuts down
                                    07-22-2024, 10:36 AM
                                  • Duranitron
                                    Asus x512dk rev 2.1 power on problem
                                    by Duranitron
                                    When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
                                    Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
                                    11-26-2024, 10:22 PM
                                  • Mita99
                                    Lenovo Thinkpad P72 EP720 NM-B723 MB - Power disabled within 2 seconds after plugging the charger
                                    by Mita99
                                    Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
                                    Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
                                    Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
                                    04-27-2025, 07:20 PM
                                  • SoulFreeze
                                    Lenovo Slim Pro 7 14ARP8 83AX No Power
                                    by SoulFreeze
                                    Hello All, I have a Lenovo Slim Pro 7 14ARP8 83AX, Board No NB6369A_MB_V5
                                    Behavior - Pressing power button results in three second led blinks on the button,
                                    Connecting charger lights up orange as normally would while charging.
                                    Connecting charger without battery blinks orange.
                                    No fanspin.
                                    Tried flashing bios, no change.
                                    I inspected the board and found a burnt component on the USB / Power button daughter board. I assume the comonent was an esd protection diode as it was on the USB A port power rails. removed the component but still exhibits...
                                    05-01-2025, 09:04 PM
