Lenovo Slim Pro 7 14ARP8 83AX No Power
  • SoulFreeze
    • Jun 2023
    • 27
    • Usa
    Hello All, I have a Lenovo Slim Pro 7 14ARP8 83AX, Board No NB6369A_MB_V5
    Behavior - Pressing power button results in three second led blinks on the button,
    Connecting charger lights up orange as normally would while charging.
    Connecting charger without battery blinks orange.
    No fanspin.
    Tried flashing bios, no change.
    I inspected the board and found a burnt component on the USB / Power button daughter board. I assume the comonent was an esd protection diode as it was on the USB A port power rails. removed the component but still exhibits same behaviour (5v is present on the usb)
    I can measure 20v on various parts of the board, but no power on any of the power inductors for GPU / CPU
    I observed that if i disconnect the daughterboard ribbon cable one fan spins at high speed otherwise still no boot or power to gpu/cpu.
    I also measured really low resistance, (around 0.2 ohm) on the GPU inductors, but i have read that that is typical for GPUs?
    Not sure where to head from here as i have no access to schematics. any pointers would be appreciated.
    Will post further findings in case of any new development
  • SoulFreeze
    • Jun 2023
    • 27
    • Usa
    Did some further digging, Found a short on this component, Marked CWFEVA, some sort of DC-DC converter. Cant find datasheets, anyone have a clue what it is?
    • mon2
      • 14684
      Attached.
      Silergy CWF*** - SY8883DFC
      • SoulFreeze
        • Jun 2023
        • 27
        • Usa
        Originally posted by mon2
        Attached.
        Thank you very much. removed the chip and the short on the inductor is gone, placed an order for the chip, so might be a while till i post any updates. Wondering if there is a simple way to temporarily apply power to the rail to do test in case i need more components, Or just wait for the chip?
        • mon2
          • 14684
          Wait for the chip. Bypass / hacks are rarely worth the risk. Aliexpress is usually quite fast these days. We are receiving packets in under 2 weeks to Canada. You may be able to find the same from a donor board / ebay, etc. but most are vendors out of China.
          • SoulFreeze
            • Jun 2023
            • 27
            • Usa
            Took a bit of a break, Managed to install the chip, laptop booted up and works fine, only issue is with audio now. speakers work but only the bass speakers on the bottom of the unit, not the front ones one the sides of the keyboard resulting in lack of high end, also headphone jack doesnt work, just static/buzzing. thinking it might be something to do with the ALC3306, though im puzzled, isnt it the same chip driving the working speakers? im assuming it has multiple channels and its partially dead?
            • WTFRules!
              Lenovo IdeaPad Slim 3 15IAN8 won´t power on after power off without AC charger plugged in
              by WTFRules!
              Hi!
              I´ve this Lenovo IdeaPad Slim 3 15IAN8 with mainboard (KS480 / KS580) NM-E901 Rev 1.0
              I receive it for repair from another shop and it had shorted EC IT8227VG-256
              After replacing it and programming it with SVOD 4 (wich is new to me as I bought it in this week) the laptop is working fine now... BUT
              Once power off from windows, it will not turn on again. When off and the power on button is pressed, a white led turns on and that´s it.
              But if you plug the charger, then all the keyboard LEDs will lit and then you get image on screen and it boots normally....
              Yesterday, 02:50 PM
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • acata
              Lenovo Ideapad slim 3 not power on
              by acata
              Lenovo Ideapad slim 3 not power on after consumer problems is can not on after sleep mode.
              And the consumer asked for reinstalling OS.
              I reinstalled windows 10 and working fine. After i leave it for updating windows and goes to sleep mode. Now it cant draw any input from power supply.
              Motherboard number is GS450&GS550&GS750 MM-C821 REV: 1.0
              Check the main power rail for 20v input ok
              No amper input from Power supply 0.013a
              Mosfet PQ201 20v and 26v ok.
              3.3v exist
              1,8v exist
              5v exist
              12v from baterai exist....
              09-30-2024, 09:42 PM
            • PantherDave
              by PantherDave
              Hi all!
              05-29-2024, 02:01 PM
            • GLISIT
              by GLISIT
              01-16-2025, 02:29 PM
