LCD Display White Screen Asus K53S
  • infotech1321
    • Dec 2013
    • 9
    • Saudi Arabia
    hello i have a Asus K53S i change the DC Jack then after when i change and open my laptop the displays a White Screen. so i try to check on external and its working ok. so i tried changing the LCD Screen same. i change the LVDS cable same also. i tried both same result. using the lcd to other laptop it is working fine.
    what is the problem i hope someone will help...
    motherboard : K53SV rev.3.1
  • ravi_1617
    YY Solutions
    • Jan 2012
    • 348
    • India
    Re: LCD Display White Screen Asus K53S
    did you checked with same size screen some times it matters a lot
    • highpulse
      i hate HP
      • May 2013
      • 1489
      • portugal
      seens to me a bended pin on the lvds socket chek well and clean well ,and retry
      • harp
        White screen repairs
        by harp
        To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
        Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
        On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
        05-13-2024, 03:43 AM
      • ahmarzo
        Asus la-7322p white screen problem
        by ahmarzo
        My asus laptop motherboard la-7322p has white screen. Have tried new screen but same problem.lcd vdd is 1.8v when i removed the mosfet an short 3vs with lcdvdd white screen is solved but no data on screen...
        07-15-2022, 07:52 AM
      • vpower
        Asus VivoBook 15 model F512D white screen
        by vpower
        I have this laptop showing white screen as soon as I push the power button, it is booting the operating system because I can hear the windows 11 intro sound. If I connect an external LCD with HDMI cable there is no image. Is it possible to hardware disable the AMD gpu in any way? Or any hint?
        Thanks in advance
        09-23-2024, 12:50 PM
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • EazyBone
        Sharp LC-65Q620U White Screen
        by EazyBone
        Another TV topic!!
        I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
        The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
        Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
        08-21-2024, 12:56 PM
