Asus A53SJ-SK230V stuck..
  • hansie55
    • Dec 2013
    • 254
    • Netherlands
    Hi Guys,
    I have an Asus A53SJ who stopped working, no video on screen and hdmi.
    When I plug in the power, some led's light up, including the power switch led.
    The powerswitch is overruled and does nothing, can't switch off the system.
    For the rest everything is dead. After a while the fan comes on when the cpu gets good warm. Tried another CPU, no change.
    Tried to recover the bios, but that does not work. This laptop does not have a automatic device selection sequence. Normally, if you want to boot from the usb, you have to select that in the bios and it only works once. Since I can't get in, this recovery can't be done.
    I can't find any schematics, only the board view. Mobo is K53SV V2.3.
    Can someone pls tell me how to approach this problem?
  • tibd
    • Oct 2014
    • 189
    • Sweden
    Re: Asus A53SJ-SK230V stuck..
    Reprogram the bios to start with. try programmer but should load the same version flashed.
    • dj_ricoh
      • 2073
      yesterday i fix one like yours with dc jack broken and after i assembled i forgot the the power button foil out! yes it was late i open 2 times the notebook and did not knew why it does not power on!
      It had tape over the foil.
      check for any corrosion on the board
      • hansie55
        • Dec 2013
        • 254
        • Netherlands
        thx, but I do not have a programmer yet and as I explained, I can't let the laptop start from usb. I wish I could. Does it automaticly seek the usb?
        • hansie55
          • Dec 2013
          • 254
          • Netherlands
          Thx. I will check for corrosion. The missing foil shorts do not apply here, because he does the same with the mobo out.
          This laptop also came in with dc jack badly repaired with too much of tin, making a shortcut and the pcs of mobo side of it were broken off.
          I fixed that as good as possible.
          • tibd
            • Oct 2014
            • 189
            • Sweden
            I would definetly try to make a bootable DOS- CD with bios.rom image and the flasher software which is possible to get through the asus website. Try to search ASUS site for a bootable CD version of bios and try with that. Boot without prepherals and HDD. I see that its not your laptop originally otherwise there should be some sort of crash-free bios launchable from included CD within the newer versions. But never to say that such was included witht this one!!!
            • hansie55
              • Dec 2013
              • 254
              • Netherlands
              Thx for yr idea, but the sytem does not boot at all, only the lights go on.
              When I try with bios .bin on usb stick and press window-key+B and plug in the power, the light goes on and off a couple of times, like he is seeking for the file but can't find it.
              • tibd
                • Oct 2014
                • 189
                • Sweden
                Then make a bootable USB with dos, copy the flash software and rom.img there and see if it helps that way. Otherwise fine someone near you to help programming the bios chip.
                Any further trouble shooting on motherboard?
                Included sw needed for creating bootable dos USB, floppy and CD. Hope you get it done. I can help flashing the chip for you but u have to send it to Sweden with prepaid return. No further charges for the programming.
                • dj_ricoh
                  • 2073
                  do you got pictures of the board?
                  hansie
                  • hansie55
                    • Dec 2013
                    • 254
                    • Netherlands
                    Thx for the offer. I might take you up on that. I will try the boot first.
                    • hansie55
                      • Dec 2013
                      • 254
                      • Netherlands
                      hansie
                      Herewith, quality is not all that, I hope good enough.
                      • dj_ricoh
                        • 2073
                        do you got any signal on hdmi ?
                        connect the fan adapter memory and power button and see if you got signal.
                        if yes go for a reflow even if not go for a reflow.
                        cook the the whole board! :>
                        • dellxps15
                          • Feb 2014
                          • 1598
                          • italy
                          i have a non working asus k54 here and it is the dc jack. seems put in place, but no 5 and 3.3 volt. if i move power cord it works, so ordered a new dc jack. mainbord looks exact like your board, so if u need some measurement, let me know.
                          • tibd
                            • Oct 2014
                            • 189
                            • Sweden
                            If you move the power cord and it works on battery then its not the power jack. Check the first two mosfet on Vin line for shorts or the charger chip.
                            • hansie55
                              • Dec 2013
                              • 254
                              • Netherlands
                              no signal on hdmi, also not with your items connected.
                              Thinking about the reflow
                              • hansie55
                                • Dec 2013
                                • 254
                                • Netherlands
                                thx for the offer, but I don't know where to start without the schematics
                                tibd: same, without schematics and the components are not numbered.
                                • sparker1
                                  • Sep 2011
                                  • 343
                                  dellXPS15 - This is the power jack with the solder connection at the back of it. I had one that had an almost invisible crack where it goes from the MB and joins the jack. It is a bad design as when you push in an adapter it pushes that pin away and it eventually cracks. My board did the same and made intermittent connection when it was manipulated.
                                  • hansie55
                                    • Dec 2013
                                    • 254
                                    • Netherlands
                                    Sparker.You had cracks. By me in this 'fine design" the piece of pcb between the power jack and the RJ45 was completely broken off and from the outside piece the last piece from the last island disapeared.I tried to solder the tracks together again with plenty tin. but I do not know if there are tracks inside the multilayer and again, no schematic, so I can't check that. Are there any extra connections besides the + and -that have to be made?
                                    • Michale32086
                                      • Nov 2011
                                      • 1453
                                      Hi Guys,
                                      It's been my experience that a laptop that powers up and all the LEDs and stuff light up but nothing is on the screen, it's likely an overheating issue...
                                      Once you eliminate the more mundane like memory, HD or battery issue, it's almost certain to be that the GPU has overheated and separated from the MB..
                                      The fix for this is a "reflow" process whereas you disassemble the laptop and put the bare motherboard on an Infrared Pre-Heater...
                                      This is what I use:
                                      http://www.ebay.com/itm/PCB-PREHEATI...item51c778bf0f
                                      Make sure you take off all the plastic sheets and covers because they will melt and could pull off components as the melt...
                                      Set the Ownta for 260c. I use a Laser Thermometer to make sure the temp in the GPU area gets to 370f which is the temp that solder begins to melt..
                                      Once you reach that temp, hit a timer for 60 seconds..
                                      Once the timer goes off, CAREFULLY remove the MB and place it on a flat surface to cool.. It will be hot and if you jar it too bad or drop it, you will lose components...
                                      I have resurrected literally thousands of laptops using this process and I have a 96% success rate on this particular symptom...
                                      Good luck...
                                      • hansie55
                                        • Dec 2013
                                        • 254
                                        • Netherlands
                                        Michale32086. thx for the advice.I will check it out
