Dell Inspiron N5030 Will not turn on!
  • rccrasher65
    • Mar 2014
    • 622
    I have a Dell inspiron N5030 that will not power on. External supply turns green, but when you press power button, nothing. A complete nube here when it comes to computer repair so be patient with me. Have no idea where to start. Thanks for all the help in advance, George
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3607
    • slovakia
    Re: Dell Inspiron N5030 Will not turn on!
    check power switch for 3.3V
    • techman1025
      • Jun 2014
      • 497
      Hi
      If ALWON voltage is there 3/5 with just adapter plugged in with out pressing power button probe around all the big square coils only two should have voltage if yes next is the bios chip known problem on this model MAIN BIO'S & EC BIOS in which is the smaller size file upload and i will give you two new file's ...i need you to compare files and in some case use your ME REGION .
      TECHMAN1025
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3607
        • slovakia
        u have amd or intel?
        • rccrasher65
          • Mar 2014
          • 622
          Whoa, slow down fellas, nube here. I need to get this thing apart. how do you check the switch I have all the equipment necessary. Work on tv's as a hobby! Complete nube here!!!!
          • rccrasher65
            • Mar 2014
            • 622
            Intel, I do believe.
            • Compgeke
              • Feb 2014
              • 524
              Being an N5030 it's Intel. If it were an M5030 it would be AMD.
              • fddizon
                • Sep 2011
                • 555
                • Philippines
                one or two pins of the switch reads 3 volts in respect to ground.
                the other one or two is/are ground. so pressing that power button shorts 3v to ground sending a signal to turn the machine on
                • rccrasher65
                  • Mar 2014
                  • 622
                  thanks I'll check that once I open her up tonight.
                  • rccrasher65
                    • Mar 2014
                    • 622
                    I do have 3.2v on pin one of the switch connector, the rest
                    of the pins are giving me readings in the milli volt range. I also saw a white light on , on the front edge of the laptop, the other two dark. It did go out after awhile though. How can I check the output of the power supply for its voltage?
                    • rccrasher65
                      • Mar 2014
                      • 622
                      I checked the switch connector, I have 3.2v on first pin. Also checked power supply connector I have 19.75v on pin one 3.2 on middle pin, and 19.75 om third pin. While just messing around, I unpluged the power supply, checked battery in there and plugged back the power supply and on she came. I have no clue what i did but it came on, what I noticed is that fan wasn't running, and it would not respond to the power switch itself, was on for about half to 45 min. I wanted to put keyboard back on so I unplugged and pulled battery, now no matter what I do can't get back on. I guess there is some hope for this unit after all. what to do next????
                      • rccrasher65
                        • Mar 2014
                        • 622
                        Gentlemen ,Is there a way to force the computer on by using the pin with the 3.2v and jump to the pin thats grounded on the connector. I think I may have done that while probing around with my meter checking voltages? computer did come on for a few seconds. where to go from here?
                        • rccrasher65
                          • Mar 2014
                          • 622
                          update, actually working on computer now. I jumped the 3.2v to ground and computer is running as we speak, I guess I have a bad switch to find and change. where can I locate a new one, can this one be fixed. How do you test the switch itself, Thanks again for your help
                          • Th3_uN1Qu3
                            Believe in
                            • Jul 2010
                            • 6031
                            • Romania
                            With the computer off and unplugged, put your multimeter on buzzer. One probe goes to the pin you found the 3.2v on, the other goes on any of the other pins. Hold the probes in place and push the button. If the beeper does not beep, then the switch is bad.
                            Using a contact cleaner spray on the switch may get it back in operation for a while, but it won't last long.
                            I have no idea where you can actually buy switches, i always scavenge them from other boards.
                            A working TV? How boring!
                            • rccrasher65
                              • Mar 2014
                              • 622
                              thanks, ill give that a try. Anyone on here have parts for the Dell Inspiron N5030?
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                if this is the same there not a bad price i guess
                                http://www.ebay.com/itm/NEW-Dell-Ins...-/280846262097
                                • rccrasher65
                                  • Mar 2014
                                  • 622
                                  yes it is the same, thanks
                                  • rccrasher65
                                    • Mar 2014
                                    • 622
                                    Thanks to all the help from the guys on Badcaps, another laptop saved from the scrap heap,problem was only a bad switch. thanks again.
                                    • Naineesh1
                                      DELL inspiron 15-3515 GDM54 LA-L245P Won't turn on
                                      by Naineesh1
                                      I just recieved a working laptop for a quick dc port swap, i tested the laptop on battery it worked, tested dc port issue felt loose, so disassembled the laptop and removed battery connector, swapped the dc port, re-connected the battery connector, inserted dc pin, white led glowed up - stable, pressed power switch, but it didn't turn on, no fan spin and no display. just 1 white led that glows up, doesn't move to orange (charging), i check voltage (battery : 11.37v) (dc input port : 19.3v)(bios : 1.75), i am stumped, there is no shorting on board.
                                      Schematic diagram : bios chip volt...
                                      07-05-2025, 01:20 AM
                                      DELL Inspiron 3671 Inspiron 3000 i3-9100 Specification for Upgrade or Repair
                                      This specification for the DELL Inspiron 3671 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3671 boardview and Inspiron 3671 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                      09-12-2024, 03:36 PM
                                      DELL Inspiron 5680 Inspiron 5000 i5-8400 Specification for Upgrade or Repair
                                      This specification for the DELL Inspiron 5680 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 5680 boardview and Inspiron 5680 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                      09-12-2024, 03:30 PM
                                      DELL Inspiron 5680 Inspiron 5000 i3-8100 Specification for Upgrade or Repair
                                      09-12-2024, 03:28 PM
                                      DELL Inspiron 3668 Inspiron 3000 i5-7400 Specification for Upgrade or Repair
                                      This specification for the DELL Inspiron 3668 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3668 boardview and Inspiron 3668 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
