I have a Dell inspiron N5030 that will not power on. External supply turns green, but when you press power button, nothing. A complete nube here when it comes to computer repair so be patient with me. Have no idea where to start. Thanks for all the help in advance, George
Dell Inspiron N5030 Will not turn on!
Tags: None
Re: Dell Inspiron N5030 Will not turn on!
Hi
If ALWON voltage is there 3/5 with just adapter plugged in with out pressing power button probe around all the big square coils only two should have voltage if yes next is the bios chip known problem on this model MAIN BIO'S & EC BIOS in which is the smaller size file upload and i will give you two new file's ...i need you to compare files and in some case use your ME REGION .
TECHMAN1025Comment
Whoa, slow down fellas, nube here. I need to get this thing apart. how do you check the switch I have all the equipment necessary. Work on tv's as a hobby! Complete nube here!!!!Comment
thanks I'll check that once I open her up tonight.Comment
I do have 3.2v on pin one of the switch connector, the rest
of the pins are giving me readings in the milli volt range. I also saw a white light on , on the front edge of the laptop, the other two dark. It did go out after awhile though. How can I check the output of the power supply for its voltage?Comment
I checked the switch connector, I have 3.2v on first pin. Also checked power supply connector I have 19.75v on pin one 3.2 on middle pin, and 19.75 om third pin. While just messing around, I unpluged the power supply, checked battery in there and plugged back the power supply and on she came. I have no clue what i did but it came on, what I noticed is that fan wasn't running, and it would not respond to the power switch itself, was on for about half to 45 min. I wanted to put keyboard back on so I unplugged and pulled battery, now no matter what I do can't get back on. I guess there is some hope for this unit after all. what to do next????Comment
Gentlemen ,Is there a way to force the computer on by using the pin with the 3.2v and jump to the pin thats grounded on the connector. I think I may have done that while probing around with my meter checking voltages? computer did come on for a few seconds. where to go from here?Comment
update, actually working on computer now. I jumped the 3.2v to ground and computer is running as we speak, I guess I have a bad switch to find and change. where can I locate a new one, can this one be fixed. How do you test the switch itself, Thanks again for your helpComment
With the computer off and unplugged, put your multimeter on buzzer. One probe goes to the pin you found the 3.2v on, the other goes on any of the other pins. Hold the probes in place and push the button. If the beeper does not beep, then the switch is bad.
Using a contact cleaner spray on the switch may get it back in operation for a while, but it won't last long.
I have no idea where you can actually buy switches, i always scavenge them from other boards.A working TV? How boring!Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
thanks, ill give that a try. Anyone on here have parts for the Dell Inspiron N5030?Comment
if this is the same there not a bad price i guess
http://www.ebay.com/itm/NEW-Dell-Ins...-/280846262097Comment
Thanks to all the help from the guys on Badcaps, another laptop saved from the scrap heap,problem was only a bad switch. thanks again.With the computer off and unplugged, put your multimeter on buzzer. One probe goes to the pin you found the 3.2v on, the other goes on any of the other pins. Hold the probes in place and push the button. If the beeper does not beep, then the switch is bad.
I have no idea where you can actually buy switches, i always scavenge them from other boards.Comment
by Naineesh1I just recieved a working laptop for a quick dc port swap, i tested the laptop on battery it worked, tested dc port issue felt loose, so disassembled the laptop and removed battery connector, swapped the dc port, re-connected the battery connector, inserted dc pin, white led glowed up - stable, pressed power switch, but it didn't turn on, no fan spin and no display. just 1 white led that glows up, doesn't move to orange (charging), i check voltage (battery : 11.37v) (dc input port : 19.3v)(bios : 1.75), i am stumped, there is no shorting on board.
Schematic diagram : bios chip volt... -
This specification for the DELL Inspiron 3671 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3671 boardview and Inspiron 3671 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...09-12-2024, 03:36 PM
This specification for the DELL Inspiron 5680 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 5680 boardview and Inspiron 5680 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...09-12-2024, 03:30 PM
This specification for the DELL Inspiron 3668 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3668 boardview and Inspiron 3668 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...09-12-2024, 03:28 PM
This specification for the DELL Inspiron 5680 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 5680 boardview and Inspiron 5680 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...09-12-2024, 03:28 PM
- Loading...
