Hp dv6700
  • p1muserfan
    • Apr 2014
    • 184
    Hp dv6700
    Got an old DV6700 with the infamous 67M-A2. It starts, all the lights come on, and the fan spins for a little over 2 seconds. Shuts down, and then the cycle starts over again in an endless loop. Heat the chip or is maybe the bios a mess? Board is the DA0AT1MB8H0 rev. H
  • degutji
    • Dec 2012
    • 173
    • Indonesia
    Re: Hp dv6700
    Common problem is BGA Nvidia G86-730-A2
    • reaper57
      • Sep 2014
      • 216
      • Norway
      Re: Hp dv6700
      Probably the gpu. You can try pressing on it or overheating it to see if it will turn on. If it does do a rework and you should be good to go.
      Keyboard not detected, press F1 to continue...
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        Re: Hp dv6700
        I have never seen BIOS issues on dv6000. It's always the darn nvidia chips.
        A working TV? How boring!
        • reaper57
          • Sep 2014
          • 216
          • Norway
          Re: Hp dv6700
          I've seen video issues on a dv5 that were caused by a bios problem. Once I updated the bios everything was working.
          • chaos-theory
            Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
            by chaos-theory
            I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
            Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
            03-14-2025, 05:37 PM
          • arabex21
            Asus Prime B450M-A starts only when 12v 8pin cpu plug disconnected
            by arabex21
            Hello everyone. I have been reading this forum for a long time - I really appreciate the amount of very interesting materials and information in the field of electronics.
            I have a problem with this configuration:
            ASUS PRIME B450M-A
            RYZEN 1300X (I replaced it with ATHLON 200GE - the same behavior, the processors are functional, tested on another board)
            When the entire set is installed (CPU, RAM, ATX connector and 12V 8 pin CPU plug), the board starts up for a while (about 1-2 seconds), the CPU fan starts and the board turns off immediately. When I disconnect...
            09-19-2024, 03:05 AM
          • master3112
            Lenovo E15 Gen.3 NM-D481 No starting and charging via USB-C, The device starts only via the battery.
            by master3112
            I have a Lenovo E15 Gen.3, motherboard NM-D481 with a defective USB-C port. The device starts with battery. When connected to the USB-C power supply, it does not start or charge. 20V is present at the input of the UT5 (High voltage USB PD power switch), 0V at the output
            UT5 pin 3 (SNK_PS_EN) =0V
            RPT3 Pin1+2 LDO 3V3 present
            I suspect that the UT2 USB-C power controller is defective because the UT5 is only controlled by the UT2. However, the UT2 supplies on pin 33 (+LDO_3V3) which makes me wonder if it is defective after all. Unfortunately I don't have it here to test it.
            08-02-2025, 12:30 PM
          • Shobos
            Dell E6420 XFR Rugged starts to boot but after 3 secs shuts down.
            by Shobos
            Hi, I bought 6420 XFR that tries to boot but shuts down after about 3 seconds, CPU gets warm, fan starts.
            So far I have tested all rails wich are good, BIOS flashed with CH341, 3.3,5, main rail present. multiple ram sticks tested. Sometimes it might stay on for longer like 4-5 seconds but not always, theres no picture whatsoever. Also on some rare occasions the caps lock flashes 1 time by itself.
            NOTE: I am using bench power supply not dell charger with ID pin and NO battery present, kinda doubtful this would cause this issue.
            Any help is welcome. Thanks !
            07-29-2025, 03:53 PM
          • JohnML1975
            LG 49UK7550PTA - after couple of hours screen starts to blink
            by JohnML1975
            Hello Forum team
            Have this TV; searched for the model and could not anything so thought I would share in here
            Had an issue, some years ago, and looks like some placed sticky tape over some of the lines on the FFC cables between the T con and the mainboard
            Anyway, the owner, who gave me the TV, says it starts to blink after a few hours
            So I removed the covers, and could not see anything visibly
            Removed the power supply and thought some of the solder joints, on the hot side, were not the best. I thought some looked like they were cracked.
            07-25-2025, 10:48 PM
