I can't resolve a problem [No Power to CPU]
    Hi guys,
    Ok, so this is my second motherboard (Dell vostro 3750) which came with no display. In both case I found the issue no power to CPU. I can't find the problem which causes the no power issue to the cpu. No short nothing.
    What do you guys think?
    Re: I can't resolve a problem [No Power to CPU]
    2 new motherboards with the same fault, thats really quite rare. I know this is is stating the obvious, but on your PSU power supply unit there will be a square plug that fits directly into the motherboard, its usually within and inch or 2 of the the cpu housing - check this part of your power supply is working and connected correctly to the motherboard.
      These are not new. These are here for repair.
        I checked PU4 NPC6131:
        Pin1 - nothing
        Pin2 - 0.86V
        Pin3 - 1.03V
        Pin4 - 0.95V
        Pin5 - 0.73V
        Pin6 - 1.03V
        Pin7 - nothing
        Pin8 - nothing
        Pin9 - 3.35V
        Pin10 - 5.05V
        Pin11 - 1.96V
        Pin12 - nothing
        Pin13 - 0.87V
        These are on.
        When off
        just Pin38 and Pin39 are present.
        Pin38 and Pin39 - 0.44V after press the power button both goes high to 5.1V.
          resolder PU4
            I did that. I also put a new one I thought something wrong with it.
            CPU has two phases and neither is working. Interesting isn't it?
              so on page 41 you got all the voltages?
                Yes, I've all the voltages.
                  PL5,PL4,PL6 and PL9 voltage.
                    o lol did you test with another CPU?
                      Nothing on PL5,PL6, and PL9.
                      PL4 is empty because CPU just uses two phases instead three.
                      I tried with different CPU but didn't help.
                        we need voltage from PU1,PU2 and PU3
