DELL N5010 Display without light
  • ravi_1617
    YY Solutions
    • Jan 2012
    • 348
    • India
    Hi, DG15 board without GPU. board has display without light .
    after searching ,BLON_OUT_C 0 VOLTS every time before /after display,One more doubt I have.
    +5V_ALW AT R5415 100K res ,Has 5 volts ,as soon as display comes it goes to 0 volts .It it fine or not .
  • dspok
    • Jan 2014
    • 553
    • Nepal
    Re: DELL N5010 Display without light
    Try with different display.
    • expertreader
      Dell 5520 not booting up - on light comes on momentarily
      by expertreader
      Dell 5520 South peak 15 MB 213253-1 2TWTT$LA
      Hi all, looking for some help to get started on troubleshooting without schematics
      I have used Dell Latitude 5530 SouthPeak15 MLK 203102-1 schematics from forum although this board is a little bit different.
      I am a bit lost on USBC PD circuit and what to measure - here is what i have done so far.
      • no coils are shorted - one is showing about 15ohms but others are in kohms or infinite resistance.
      • most of the coils are showing 5V, 1.3V, 3V etc except 2 of them.
      • i have measured 16.5V available at the capacitor
      10-19-2025, 08:20 PM
    • minaedward
      Dell N5010 keyboard
      by minaedward
      Hi all
      I have a dell n5010 that shows black screen after the dell logo and freezes
      But when I remove the keyboard it works fine and boot the windows
      The keyboard is working as I can press F1 and F2 and inter the bios settings and change it
      But after the dell logo it causes the laptop to freeze
      Any ideas why ?
      09-29-2024, 05:24 PM
    • multimesut
      Dell 2007FPB Yellow Light Problem
      by multimesut
      Hello friends,
      A yellow light was flashing on my monitor. It was like it was constantly cutting power. When I opened it up, I saw that the big capacitor in the high voltage line was leaking. I replaced it. When I turned it on for the first time, it had the same problem again. But then, interestingly, it got better. The yellow light was on steady. But the monitor wouldn't turn on. When I examined them with a thermal camera, I saw that the Fli5961-LF reached 50 degrees Celsius and the EM636165TS next to it reached 100 degrees Celsius and was drawing high current on the motherboard....
      11-13-2024, 07:00 AM
    • zwect
      Dell Latitude 5420 / GDF40 LA-K491P REV 3.0 / Amber / Orange light when power button is pressed
      by zwect
      I have this Dell Latitude 5420 with ST: CMF62F3, board GDF40 LA-K491P REV 3.0 that does not power on, i already searched for some clues about this problem that happens on mine but no BIOS i downloaded and flashed did anything.
      Only when the power brick is connected, when pressing the power button an amber light lights up at the front and slight decreases its brightness, the RAM and the CPU seem to heat up if the laptop is left connected but nothing else, other than USB devices getting powered.
      Here is the original BIOS dump from the 25R256JVEN chip.
      09-11-2024, 05:54 PM
    • Akhlz001
      by Akhlz001
      09-20-2025, 07:15 PM
