Asus U47A Laptop - Power Supply Shorts Out + Smoking Component
  • PohTayToez
    • Jun 2010
    • 80
    Got a laptop in with an odd power issue. When the power supply is plugged in the green indicator light on the power supply goes out. Tried a new power supply which does the same thing. Removed the motherboard to check for power jack or component damage and found nothing, but when I plugged the power in I found little wisps of smoke coming from one of the components. Tested the resistance on the component which read 1.1 Ohms one way and .7 Ohms reversed. Any ideas?
    Higher Quality Image, Component Circled in Red
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3607
    • slovakia
    Re: Asus U47A Laptop - Power Supply Shorts Out + Smoking Component
    it just capacitor on main rail. u can remove it and it should work.
    or u can replace it with same size by any capacitance. its capacity is not important
    • selldoor
      Slow Learner
      • 7870
      Looks like a shorted capacitor - old dell 505s used to have a similar problem removing it seemed to get them working. If you cant find the value try something a similar physical size
      and capable of standing the voltage on the pads
      • PohTayToez
        • Jun 2010
        • 80
        When I remove it do I connect the two pads with solder or leave them disconnected?
        • selldoor
          Slow Learner
          • 7870
          Leave it disconnected. or replace with another capacitor.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            It is not critical. It's best to replace it with a capacitor of the same size taken from a similar location on a scrap board, but it will work without that capacitor installed. Shorted ceramic capacitors are way more common than you would think, especially if the laptop has been used in an area with high humidity.
            DO NOT bridge the connections with solder - you've got a direct short across the power adapter, you're trying to remove the short, not make it worse.
            A working TV? How boring!
            • PohTayToez
              • Jun 2010
              • 80
              Sorry for my ignorance :P
              Wanted to report that the laptop is in good working order now, thank you very much everyone for you help.
              • abshah847
                • Oct 2023
                Hello, I had the same issue with the Asus Q400A. I tried 2 different PS and soon I plugged them to the laptop they would short out. Next I checked the voltage on 1 positive point and 4 ground points and it was reading zero also bad capacitor and it was reading zero. Removed the badcap and worked so far no issue. Thank You to everything who helped and kept the earth green from the waste. I have one question: does anyone know how to make the backlight work on the keyboard on Asus Q400A. I tried FN4 and F3 and F4 keys combination and it didn't work. Do I need to install some utility software for it?
                  • 21145
                  https://www.badcaps.net/forum/showpo...43&postcount=5
                  4.4. Asus
