asus a42j no power
  • reizal
    • Oct 2014
    • 111
    • aceh
    asus a42j no power
    hi all
    i have asus a42j core i5, problem no power, no led, nothing, someone can help me?
    Hidup yang benar2 membosankan.. hek that bak mita peng
  • meritosari
    • Oct 2010
    • 774
    • Indonesia
    Re: asus a42j no power
    Do not connect the adapter and laptop battery.
    check if there is a short circuit on the 19v lines.
    • reizal
      • Oct 2014
      • 111
      • aceh
      I will learn it, I was still hard how to read schematics, because I am still learning, thanks
      • masud
        • Jul 2011
        • 317
        • Bangladesh
        can anyone please brief how to read/ use the schematic diagram to repair a laptop motherboard.
        thanks.
        • reizal
          • Oct 2014
          • 111
          • aceh
          now can live with using batt, but using the adapter can not be, anyone can help, where should I check
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3593
            • slovakia
            check first two mosfets right after power connector for voltage on its legs. go for traces. if is dot on trace look on other side
            • meritosari
              • Oct 2010
              • 774
              • Indonesia
              check the three components that have been marked, the p-channel MOSFET
              • JJR
                • Mar 2013
                • 171
                PJP8101 looks damaged top left corner
                • reizal
                  • Oct 2014
                  • 111
                  • aceh
                  Thank U all for help me
                  • GLISIT
                    by GLISIT
                    01-16-2025, 02:29 PM
                  • PantherDave
                    by PantherDave
                    Hi all!
                    05-29-2024, 02:01 PM
                  • ShadowAi
                    ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                    by ShadowAi
                    Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                    Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                    After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                    03-15-2024, 10:46 AM
                  • meraklinetx
                    Asus Z97-a power cycle, no boot no cpu voltage
                    by meraklinetx
                    Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                    05-10-2023, 06:08 AM
